Old 03-25-2015, 11:36 AM   #1
How long to de-winterize
First season. We're headed to Washington DC Friday am and wondering about how long it takes to wash the antifreeze out of the system. Does it leave an aftertaste in the drinking water? I'm trying to figure out if I will do it here in Ottawa while we're close or below freezing or wait till we get to Washington. Thanks all!
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 03-25-2015, 12:56 PM   #2
ColoradoRick's Avatar
I like to dewinterize while parked in the street at my house because the street drain is right next to where I park the camper.
I hook up the water with my hose and flush all of the lines. Then, I'll pour about a cup of bleach into the fresh water tank then fill it up. Then, I'll flush this bleach solution through all of the lines and then let it sit for an hour or two to disinfect everything. (The fresh water tank can get a nasty rotten egg smell if it's not disinfected.)
Then, I'll drain the fresh water tank (valve under the camper) and fill it and drain it, again then run fresh water through all of the lines, again.
Now, it's important to NOT open the bypass valves on the hot water heater until AFTER you've done all this...no reason to flush out or run bleach through the water heater. (You can buy a little hose to put into the water heater to flush it out.)
Even after doing all this, you still may smell a bit of bleach for a little while but flushing the water a bit will get rid of it.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 03-25-2015, 01:15 PM   #3
2015 Forester MBS 2401W
HomeOnWheels's Avatar
Newbie question - instead of using the drain valve, is there any benefit to flush the bleach water through faucet, sink, shower, down to grey tank and clean these systems as well?
HomeOnWheels is offline   Reply With Quote
Old 03-25-2015, 01:17 PM   #4
geotex1's Avatar
The entire freshwater system should be sanitized.
geotex1 is offline   Reply With Quote
Old 03-25-2015, 02:00 PM   #5
Yes but trying to run over 30-gallons of the fresh water (using the water pump) through everything would take forever...that's why I'll run it through everything and then drain the fresh water tank onto the street. (Which can take a few hours...just enough time to let everything soak!!)
Rick & Karen
Monument, Colorado
Old 03-25-2015, 03:20 PM   #6
geotex1's Avatar
No, I agree. When you fill your tank, you pump enough through to fill all of the FW plumbing and top off the tank and let it sit. I personally do 4 hours because I winterize by blowout. Should do your FW hoses too. My sanitizing is an all day affair because I do multiple rinses and then a fresh fill of the tank and water heater as I travel full always.
I was just answering the direct question at the time.
Old 03-25-2015, 03:33 PM   #7
Thankfully we live in Southern California and don't normally need to winterize. But I'm still thinking about sanitizing the fresh water system periodically. Does anyone living in the warm area have specific recommendations - yes/no or how often?
Old 03-25-2015, 03:37 PM   #8
geotex1's Avatar
When I lived in Texas, once a year minimum and as needed if there was odor or other cause for concern.
Old 03-25-2015, 04:31 PM   #9
Ecopco's Avatar
Here's a good video courtesy of The RV Geeks on YouTube. http://youtu.be/jEepug8N-aE
2015 Solera 24R
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
Ecopco is offline   Reply With Quote
Old 03-26-2015, 12:19 AM   #10
Sandiegodoug's Avatar
Never sanitized in 2 3/4 years.
But I always drink bottled water
Just shower and do dishes with fresh water.
Sandiegodoug is offline   Reply With Quote
winter, winterize
