Old 05-22-2015, 09:04 PM   #1
Question How to remove glass from side mirror
We have received our side mirrors and want to install them on the mirror. We can not figure out how to remove the glass. We googled it and found a video showing to push the bottom of the mirror in and grabbing the top of mirror and pulling up. So far this is not working. Need your help.
2015 Solera
Rottiemom is offline   Reply With Quote
Old 05-22-2015, 11:40 PM   #2
Did you try searching on a Sprinter forum like this one. Sprinter - Sprinter-Forum
Old 05-23-2015, 07:33 AM   #3
I do not know if is the video but it looks pretty easy here:
CaptDan is offline   Reply With Quote
Old 05-23-2015, 12:55 PM   #4
OK, our mirrors do not come off like the video. But we did get them off. We have the side camera mounted to the left mirror. Eating lunch then will put the camera on the right side. LOTS of work. Thanks for the replies.
Old 05-23-2015, 02:04 PM   #5
So how did you get them off then.
Old 05-23-2015, 03:00 PM   #6
The bottom mirror you just pull straight off. The top mirror has 4 clips. Push the bottom of the mirror all the way in and you will see 2 clips on top. Use a piece of hooked wire and unclip them the mirror will then fall towards you. Ta Da !!!! They are off.
Old 05-23-2015, 03:02 PM   #7
The right side camera in now installed. It went much faster after we learned from the left side how and what to take apart. Now all we have to do is connect them to the turn signals.
Old 05-23-2015, 05:24 PM   #8
Mikegjax's Avatar
Do you have photos of those cameras installed. Sounds like a nice concept.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 05-23-2015, 05:32 PM   #9
I took pictures but not sure how to post them.
Old 05-23-2015, 05:36 PM   #10
Mikegjax's Avatar
You can upload the photos from your computer to the forum and attach them to you post. When you submit a reply, scroll down on the page and you will see where you can create an attachment and the type of file ext that can be used.
Or, if you have a link to where you acquired the cameras you can directly paste it in you reply.
2014 Solera 24R
USN Retired
