05-03-2015, 01:11 PM
2015 Forester MBS 2401W
How to remove sealant on skylight?
The skylight is covered with a lot of sealant. I'm not going to complain much about the poor workmanship here but want to know the best way to remove it. I prefer solvent rather than scraping to avoid damage. Thanks for your input.
Jeff
Jeff
05-03-2015, 02:24 PM
Hope you'll get some ideas, but I can't think of anything that will remove the sealant, without damaging the skylight. I'd ask you dealer to handle it, or replace the skylight. I agree with the slippy workmanship though.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
05-03-2015, 03:19 PM
Is that picture showing the inside under the sky light or the roof ?
Henry & Tena
05-03-2015, 03:26 PM
I would try WD40 with a LOT of patience... and probably a few choice "blue" words in the process.
05-03-2015, 04:13 PM
It's outside on the roof, very visible from inside.
Jeff
05-03-2015, 04:21 PM
Looks just like every skylight I have ever seen. I used wife's hair dryer with putty knife.. Heat gun will work, Careful with solvents. Some, most, will penetrate the membrane and loosen the glue holding the rubber roof doen.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
05-03-2015, 07:23 PM
WD40 did the trick! I sprayed carefully on the spot, used a paper towel to wipe off excessive amount. Waited about a minute and the sealant became soft. Then just used a brush, paper towel and fingernails to remove it. Finished the job with windex. Looks fine now.
Jeff
05-03-2015, 07:24 PM
Picture after clean.
Jeff
05-03-2015, 07:31 PM
If they would use a little self control and steady hand when they applied caulk to these trailers they could probably knock a grand off the price.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
05-04-2015, 03:25 PM
Whats the difference. Did you just clean or re-apply new.
05-04-2015, 03:48 PM
2012 Solera
Good catch "OldCoot"....
05-04-2015, 03:56 PM
Thanks OldCoot for the simple trick!
StillKickin - the difference is on the surface of the skylight - no more sealant. See the first picture I posted.
05-04-2015, 04:01 PM
You are welcome, cleaned a variety of sealants, caulking, grease, etc off my hands with WD 40 over the years. It will even work somewhat on silicone caulk (tongue in cheek).
05-04-2015, 05:42 PM
I think he cleaned the acrylic cover
05-04-2015, 09:24 PM
Got it. I see your concern about the poor workmanship. Nice clean up.
