Old 12-30-2014, 12:31 AM   #11
Originally Posted by camaraderie View Post
You CANNOT measure charging amps with a $10 multimeter. You need a clamp meter with a DC amp reading capability.
But it's not necessary to be checking the amps so he can save himself the $50 and just ensure that the volts are there. It's the volts that "push" the amps.. so if he's getting 14-14.4 at the battery connections.. it's about a given that he is getting the maximum amps his converter is able to deliver.
Just sayin....
rana is offline   Reply With Quote
2013, inverter, solera
