Old 08-29-2014, 08:00 PM   #1
khocke's Avatar
Jefa Tech repeater thru-roof install NO DRILLING!
I really lucked out installing a Jefa Tech repeater antenna on my Sunseekolera 2400R today. I bought a Winegard CE2000 entry plate for the add'l cable. It's the same size and screw pattern as the single plate I un-Dicor'ed:
When I got the plate off, I was presented with a nice big hole that was plenty big to thread the new omnidirectional cable thru (I did have to cut off the cable end connector that attaches to the router though), right alongside the antenna cable. That's the antenna cable pulled up out of the factory hole, with the union connector. Don't know why they'd have a cable connector there but I guess it's an assemble plant thing. I put my unused drill away.
Here's where I completely lucked out: The cut-end of the Jefa cable ended up right in that little space where all the other antenna stuff is. I pulled it thru the grommeted hole that the TV cables are snaked thru:
I can work a soldering iron pretty well and spliced the cutoff end back on to the cable I pulled thru the roof. The Jefa antenna comes with a mounting plate that I bent to fit around the Winegard mast. Those masts are very thin and I didn't think screwing the antenna plate to the mast would hold up. Two stainless worm clamps worked nicely. Here's a shot with the 1st one installed.
About a half-tube's worth of Dicor 501LSW and done.
While I was up on the roof, I also replaced the stock Winegard Sensar head with a Sensar Wingman and had my 2nd pleasant surprise of the day. I'm in NE NJ and tripled my channel count to just over 30 stations. Clean living' I guess. Hopefully the Jefa system will prove itself in a couple weeks when I put it to a campground test.
khocke is offline   Reply With Quote
Old 08-29-2014, 08:24 PM   #2
B and B's Avatar
Nice work! Good. Looking job!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-29-2014, 09:24 PM   #3
Approximately how tall is the antenna when the tv antenna is lowered? Very interested in your results.
13larry is offline   Reply With Quote
Old 08-29-2014, 09:34 PM   #4
khocke's Avatar
Lowered, it's maybe 4-5" inches off the roof because it's parallel with the masts. Crank down the TV antenna, and the wifi antenna lies down flat too. Forget to lower the TV antenna, and I can kiss them both good-bye pretty quickly!
Old 08-30-2014, 10:43 AM   #5
hkreck's Avatar
Thanks for providing the pictures sure helps in understanding what you did. Good job.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 08-31-2014, 09:19 AM   #6
khocke
Very Nice Pic's-Thank you for sharing your Jefa Tech repeater build-up.
CaptDan
CaptDan is offline   Reply With Quote
Old 08-31-2014, 11:51 AM   #7
hkreck's Avatar
Let us know how that repeater works for you.
Henry & Tena
2013 Solera 24S
The Great Escape
roo, roof
