Old 06-14-2015, 11:56 AM   #11
I went w/Koni FSDs about a year ago. Yes they cost more, ride and handling w/Helwig sway bar is phenomenal. Big improvement and when towing the Konis really standout. Konis also carry lifetime replacement warranty. Yes the do cost more, but believe well worth it.
jlewis3323 is offline   Reply With Quote
Old 06-14-2015, 07:25 PM   #12
front & rear?
I' about ready to do the same. Did you put them (Koni FSD's) front & rear only. I'm thinking rear only?
Mike&Susan
motorscooter is offline   Reply With Quote
Old 06-15-2015, 09:40 AM   #13
The valuing on a Koni shock is "harder" then most if not all Bilstenins so if you are looking for a smother ride Konis are not the way to go.
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 06-15-2015, 09:44 AM   #14
All shocks are not created equal, Konis are built for handling so they are going to be a stiffer shock, Bilsteins are built for all around and they have a patent on their valving so it gives you a smother ride. But some applications only have one or the other or neither, so you will need to look at that first.
B.Smith
Old 06-15-2015, 11:55 AM   #15
That is just not true, there is a lot more to shock valving that just harder or softer. I have used both and the Koni is much smoother for small irregularities such as expansion strips, even if they are fimer for large movement. You would need to see the damping curve for each to know for sure.
caesar101 is offline   Reply With Quote
