Old 12-15-2013, 07:38 PM   #11
I've never turned mine off. Wouldn't know where to even look to do it! Guess I better find out.
DebbieMH is offline   Reply With Quote
Old 12-15-2013, 07:52 PM   #12
One is off and the other is on until it is empty, then it's closed and the other opened while the other is being filled. Once filled, it is left closed until the other is empty...
One tank is always on.
Old 12-15-2013, 08:43 PM   #13
Originally Posted by OldCoot View Post
One is off and the other is on until it is empty, then it's closed and the other opened while the other is being filled. Once filled, it is left closed until the other is empty... One tank is always on.
Ok, now I'm super confused - there are two propane tanks in a Solera?
Old 12-15-2013, 08:58 PM   #14
Mine is off unless we are using heat or the cooktop. 80% of our trips usually start with a tunnel transit so the propane is off by DOT regulation.
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 13 days
mogman is offline   Reply With Quote
Old 12-15-2013, 09:22 PM   #15
Sorry, I have a 5ver. Should have seen the post was in the Solera. My bad.
Old 12-16-2013, 07:31 AM   #16
Displaced2's Avatar
There is only one tank on the Solara and usually only one on motor homes.
Displaced2 is offline   Reply With Quote
Old 12-16-2013, 08:02 AM   #17
Campster's Avatar
Always stored off after returning from trip....
Campster is offline   Reply With Quote
Old 12-16-2013, 08:39 AM   #18
boats742's Avatar
Open the outside access door marked "Propane"
The shut-off valve is on the tank, round gold knob about the size of a silver dollar. Turn all the way right to close (but not too tight).
2013 Solera 24S
Charleston, SC
boats742 is offline   Reply With Quote
Old 12-16-2013, 08:55 AM   #19
GM
bclemens's Avatar
Originally Posted by 2012WhiteSolera View Post
Thanks for the heads up. I wonder since you mentions another occurance, whether there is a product defect. Bclemens, have you heard of anything on this, sounds serious.
I have not heard or seen any large scale issues nor recall mumblings. I saw a few this year, enough to prompt a call to "carfagna"??? the regulator mfg to figure out if they had any issues.
Have heard nothing since. Sounds like if there was an issue it seemed to be a small batch or we would have heard many more. I'll pose the question again and see if they narrowed anything down.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 12-16-2013, 09:37 AM   #20
boats742's Avatar
Here's another thread on the forums about leaking regulators.... Should I have both replaced with a different manufacturer?
aarrgh.. propane regulator leaking
2013 Solera 24S
Charleston, SC
leak, propane
