Old 08-08-2016, 06:22 PM   #1
Leak in cab of 2017 2401W
When I picked up our two month old 2401W today I checked top make sure it was dry. Everything looked good. The first time I stopped water came pouring out from the plastic surrounding the windshield. This was a significant amount of water. Suggestions? Is it safe to walk on the roof? Any precautions I need to take?
ID:	116673   Click image for larger version
BMW Rider is offline   Reply With Quote
Old 08-08-2016, 06:32 PM   #2
Go look in Mercedes Benz Sprinter chassis instead of Solera. A lot of recent activity about this.
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 08-09-2016, 08:12 AM   #3
Mikegjax's Avatar
It is safe to walk on the roof. Do it quite often. I usually crawl since I am not so steady on my feet anymore and use a good set of knee pads(not the hard slippery kind). Just use normal safety precautions to insure you don't fall off.
When I first got my unit I had a small amount of water intruding through the clearance lights while driving. I pulled them off and resealed behind the mounting plate and completely sealed the wire passages. No more problems.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 08-09-2016, 06:19 PM   #4
Farkasb's Avatar
At the end of this post I talk about my cab leak issue. What have you done to customize your MBS 2400 series motor home
2016 Forester 2401WS
Farkasb is offline   Reply With Quote
leak
