Old 04-05-2014, 07:48 PM   #1
Life to an old thread
I tried to put this in the Muphery Bed thread and couldn't post it there. Just thought it might help some of the MB users.
Well went out to get the MB made up to take a trip and it wouldn’t go up or down. The controller lost it mind I guess, I used the attached sheet from Lippert to get to working again. Showed the “9”error code performed the manually override worked the bed up and down then pushed the mode button again, and it went to working right. It would be good to keep a copy of this and an inspection mirror in the RV at all times could get you out of a pinch with the bed or slide. I really need to relocate the controller for the bed, good thing it was in the up position so I could get to it from the inside, and not have to go in from the outside.
pinkstonj is offline   Reply With Quote
