Old 12-25-2013, 08:38 PM   #41
Magnadyne radio time changes.
Originally Posted by MikeA View Post
Is there a way to use the GPS without listening to background hum from the radio?
Mike
Yes. Select a source such as USB or the auxiliary input (I can't remember the exact names on the screen). Basically pick a source other than radio. Then go into the GPS. There won't be any background static.
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 12-25-2013, 08:42 PM   #42
I have done that, but it seems a bit tedious, especially when starting the unit up.
Mike
MikeA is offline   Reply With Quote
Old 12-26-2013, 06:27 AM   #43
MountainTrippers's Avatar
Magnadyne
Just another one of the many Magnadynes many features.
George & Karen
2014 F150 4X4 5.0L 3.55 Axle
Husky Centerline TS 1200lb 4 point WDH
2017 Rockwood Mini Lite 2109S
Palmyra,VA
MountainTrippers is offline   Reply With Quote
Old 12-29-2013, 11:09 PM   #44
GM
bclemens's Avatar
Just to follow up, Magnadyne continues to work on bug fixes and has been releasing software updates. From what I have seen their service and support has been pretty good.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 01-07-2014, 08:01 PM   #45
Originally Posted by DebbieMH View Post
Best to ask Santa for a Kenwood unit!
I know you've posted this before, but I can't find it ... what model Kenwood did you go with? And do you like it?
Thanks Debbie.
Larry, Paula & Bailey the Adorable Red Toy Poodle
aspengirl is offline   Reply With Quote
Old 01-07-2014, 08:38 PM   #46
I love our Kenwood. Unfortunately, the one we bought is no longer available.
DebbieMH is offline   Reply With Quote
Old 01-07-2014, 08:58 PM   #47
Thanks. I'll just search their website and see what I can find.
Old 01-07-2014, 09:16 PM   #48
2012 Solera
Thanks Debbie.
I went a slightly different direction than did Debbie and others. I replaced our Magnadyne with a (non-GPS) Kenwood DDX 470 (about $300 from Amazon - Amazon.com: Kenwood DDX470 Double Din: Car Electronics). Also added a "stand alone" GPS - a Garmin RV760lmt. I like having the GPS independent of the entertainment center - I like the map visible continuously. Also, the 760lmt has "lifetime" map updates and trafffic. I mounted the Garmin above the radio in the center dash well - used a Garmin beanbag-type mount, raised about an inch with a fill board. We also really like the Kenwood. I had to replace the Magnadyne connectors with the Kenwood connectors, but did not have to pull any new wires. The Kenwood mount worked fine in the hole the Magnadyne came out of. I did add a push-button dimmer (breaks the connection to the headlight wire to "undim" the display) as the Solera has the headlights on full time.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 01-07-2014, 09:24 PM   #49
Thank you for this information. With the Garmin being a separate unit, can you easily take that with you, for instance, if you wanted to use it in another vehicle?
Old 01-07-2014, 10:14 PM   #50
2012 Solera
Very easy to unclip and use elsewhere. If in another vehicle easiest with a second cord and mount.
JLeising
2012 Solera "S"
Calif SF Bay Area
radio
