Old 08-06-2015, 12:47 PM   #1
Maiden trip in 24R Solera
We pick up our brand new 24R Solera last Thursday put 1,000 miles on our first trip. The following is our comments:
1. We love the RV and it exceeded all our expectations
2. We had a very positive experience with RV One Direct on the start up/training walk - we found a few minor items and they corrected everything in a few hours.
3. The AC was really loud - does anyone have a similar experiences
4. The AC will not work unless you are hooked up to power at a camp site, so it will not run on the generator or batteries - is this correct?
5. The power antenna worked at our walk thru with the dealer but did not power up when we tried in on our way back.
6. I looked for the second year warranty application and it was not in the RV - Called FR and found out they do not offer a second year warranty for the Solera - is this correct?
Again we are very happy with the Solera and look forward to many years of enjoyment.
DStaehlin is offline   Reply With Quote
Old 08-06-2015, 01:12 PM   #2
Petersb's Avatar
First trip
Congrats wish we could say that we don't get ours until mid sept I hope 24s
Petersb is offline   Reply With Quote
Old 08-06-2015, 01:22 PM   #3
Citrus County, Fl.
GL1800Rider's Avatar
Only towables have 2nd year warranty available but a lot of items have 2 years and/or an option to purchase an extended warranty (Dometic 12cu ft fridge)
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 08-06-2015, 01:30 PM   #4
2012 Solera
The AirCon and the microwave need 110 volt AC to be used - either shore power or generator. AirCon should run on generator, but not with other "high power" 110 volt items. Particular high power items to pay attention to are the water heater (you can turn off the 110 volt and use with propane) and the microwave (just don't use it while using AirCon). Other "moderate" 110 volt power users are the refrigerator (can switch to propane) and the converter, if the 12 volt batteries are low or if a lot of 12 volt items in use. I find I can use the AirCon (even with the microwave) on generator as long as I keep the water heater off or on propane - I have the propane generator (3600 watts vs 3200 watts for the diesel generator) and the 13500 btu AirCon. Suspect may be more of an issue with the smaller diesel generator and/or the larger 15000 btu AirCon.
As for AirCon noise, somewhat loud. Be sure your AirCon is flowing through the ceiling vents rather than dumping direct (direct dump does cool faster, but is louder). You could also experiment with fan settings - on the thermostat select "fan", then use the "+" and "-" keys to select among Hi, Lo and auto. Most of us use "auto" - the fan will be fast to cool more quickly when needed, will slow down as the temp in the MH approaches set point, and will turn off when the AirCon reaches set point and cycles off. Set on Lo the fan will run continuously at a slower (quieter than Hi) speed. You may find this less objectionable noise- wise.
Good Luck and enjoy!
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-06-2015, 01:32 PM   #5
Pod2Vibe's Avatar
3. If vents on AC main grill in kitchen are closed, it is not as loud. It will send more AC to ducts. Also, if you switch the fan setting to low on the thermostat, that will reduce noise. We do that at night.
4. The AC works great on the genset. Generator will need to be running for 30 seconds or so before AC will kick on. Will not run on battery.
5. TV Ant has two power switches. One on the TV wall plate in the cabinet and one on the right side of the antenna dial on ceiling. We keep the one on the Ant on and use the one on the base plate as on/off.
6. Correct. Extended warranty is available from dealer or folks like Good Sam.
Enjoy the new rig!
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 08-06-2015, 01:38 PM   #6
Pod2Vibe's Avatar
JLeising has great comments, expanding on the AC operation, above.
He can also speak of how the extended warranty helped him recently.
I have the same warranty and am quite glad I do.
Pod2Vibe
Old 08-06-2015, 01:46 PM   #7
Mikegjax's Avatar
If your Microwave panel lights are on with the Gen running you are getting 110 AC volts and the Air Cond should work. If the panel lights are off you may need to reset the CB on the Genset. The reset is under the Genset cover near the local start switch, on the side.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 08-06-2015, 01:46 PM   #8
halbright's Avatar
1. That's wonderful. I found several things for my punch list on my unit, some of them blatantly obvious that should have never occurred or should have been corrected by the factory or the dealer before I ever saw the unit.
2. I'm glad you had a good experience with RV One Direct. My experience with them in Buffalo was not that good. They are nice people, but I did not like their process. They clearly did not do what they claimed they do on a PDI or my punch list would have been much smaller.
3. Our AC sounds like those all in one units in some hotels/motels. I don't know if it got quieter or if we just got used to it, but it's not bothersome.
4. AC should work on the generator. It takes a little while for the system to recognize generator power, then the AC unit takes a moment or two to start the fan, then the compressor.
5. There are two buttons required to turn on your TV antenna. One is in the cabinet on the cable outlet box, the other is on the ceiling where you adjust the antenna. The one in the cabinet is almost invisible. When it is on, you will see a little green light on the cover plate.
6. There is no second year warranty option on the Solera.
I am glad that you are happy with your Solera. My wife loved ours from the start. I am loving it, too, now that I have addressed all of the items on my punch list. Everything works as it should and it is fun to drive and nice to enjoy on the road and at our destinations. Getting there really is half the fun.
halbright is offline   Reply With Quote
Old 08-07-2015, 11:48 AM   #9
i run generator for about 2 min and then turn on the a/c unit
locogk is offline   Reply With Quote
Old 08-07-2015, 12:13 PM   #10
Thanks to everyone's great thoughts and assistance - you guys are great and really appreciate all the help!!!!!
I did find the second switch for the power antenna, and the A/C runs much quieter by having the air flow through the vents -Thank You!
I do have a follow up question on the Generator.
I paid for the upgrade for the diesel generator 3200 watts, and I turned off the refrig and water pump and started up the generator and waited for five minutes and then turn on the fan first and then the A/C to low - as soon as switch on the A/C the generator kick off.
Did I make a bad decision on going with the diesel generator?
solera
