Old 07-24-2016, 04:40 PM   #1
Maintenance computer warning & OBD
How do I reset the Maintenance warning info on the dash? Also, where the heck is the diagnostic link connector for a scanner on the 2015 24R?
Thanks.
lacamastraveler is offline   Reply With Quote
Old 07-25-2016, 12:19 AM   #2
dukeboone's Avatar
Look for the OBD port in the fuse panel near the hood release. After releasing the plastic panel to access the fuses there's another OBD port sized door covering the port itself. The port faces downward. I believe the service reset is accessed by holding down the "O" button on the instrument panel until you hear a beep. (you'll have to wait longer than you think, some report 30 seconds, but I don't think it's that long) This will allow you to access several cryptic menus that you can cycle through using the "M" button on the instrument panel. I believe you then scroll through until you arrive at either .51 or .21 depending on the spec of oil that was used. At that point there's another button sequence to initiate the reset and I'm sorry, but I can't quite recall what it is. MNTraveler has posted some video links about accessing these menus in the MBS forum.
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 07-25-2016, 07:09 AM   #3
Mikegjax's Avatar
Thanks.
Try this.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
maintenance
