Old 11-15-2014, 01:39 PM   #1
Mikegjax's Avatar
Metal valve stems
Finally had the metal valve stems installed. What a difference when it comes to checking/inflating. Don't need three hands anymore. TPMS should be here in a couple more days.
DL1SP13FR Chrome Duallyvalve Kit W/ Front Stems
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-15-2014, 02:29 PM   #2
Well...they ain't cheap! How much did it cost to get them installed?
Probably a good idea in any case.
Dave
DaveJordan is online now   Reply With Quote
Old 11-15-2014, 02:34 PM   #3
trbomax's Avatar
They didnt cost me anything. The tire shop where I buy all my tires just put them in when I ask ,and no they didnt jack the price of the tires to cover it as I had already paid for them.They were in a box next to the rubber ones on a shelf above one of the tire machines.The price was written on the boxes,$1.50 for rubber and $2.50 for metal.
edit) I reread this and see you wanted chrome ones,brass was good enough for me!
trbomax is offline   Reply With Quote
Old 11-15-2014, 02:45 PM   #4
Wow - where do you get your tires??? A set of duallyvalve stems - inside and outside for the rear, plus fronts, plus grommets to protect things, etc., seems to go for a bit more than $100 in brass...only $10 more for chrome...
Old 11-15-2014, 03:13 PM   #5
Mikegjax's Avatar
Cost roughly $20.00 each to have installed. Would have been much cheaper if I had it done with tires. Don't need tires for awhile! What I like about these stems is NO EXTENSIONS.
2014 Solera 24R
USN Retired
Old 11-15-2014, 03:21 PM   #6
trbomax's Avatar
Tim's Tire in mancelona mi.
Old 11-17-2014, 07:16 PM   #7
Mikegjax's Avatar
Added Tiretech On TPMS today. Very easy install even on front stems. Did need to bend the front stem slightly. Taking the RV out next week and will see how it works. From what I can tell it is the exact system as Tireminder and Tiretracker, but a bit cheaper to buy.
2014 Solera 24R
USN Retired
Old 11-17-2014, 07:32 PM   #8
Boss Hoss's Avatar
Metal valve stems are always better-they won't rot in the sun light.
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 11-29-2014, 06:25 PM   #9
Mikegjax's Avatar
Happy to say the Tiretech On TPMS works very well. Easy install and setup and provides accurate pressures and temps (verified temps with infrared thermometer). The monitor is about the size of a small flip phone, closed. Easy read face and function. Mounted it with it's suction cup mount to the forward edge of the small drivers side window which makes it non intrusive. When I received it there were 6 extra batteries which surprised me.
Here is a link for those interested.
Tiretech on Tire Pressure Monitoring System w 10 Brass Sensors 0 232 PSI TP7004 | eBay
2014 Solera 24R
USN Retired
Old 11-29-2014, 09:44 PM   #10
"Very Nice"-Thanks for the INFO. This is the next Mod I need for my one piece metal tire valve stems" that I bought from Your Tire Shop Supply | Supplies for Tire Shops
Thanks again.
Capt Dan
CaptDan is offline   Reply With Quote
