Old 12-15-2015, 03:45 PM   #271
I just purchased an amazingly powerful cordless vac for our Solera - the Makita XLC02R1W. It comes with a battery and charger, or without. I already use Makita cordless tools, so have a spare Drill and a fancy LED lantern/flashlight DML806 that all work with the same battery and charger. The Vac is noticeably more powerful than our cordless Dyson, and a bit handier because it is smaller.
nusslejj is offline   Reply With Quote
Old 12-15-2015, 03:49 PM   #272
Has anyone considered replacing the LARGE A/C unit on the Solera with a low-profile one ? I put up a metal building to store the SOLERA, and we had to go to a full 12' opening, and it only clears by 5-6 inches. Plus the A/C adds more DRAG.
Old 01-22-2016, 11:48 AM   #273
Mikegjax's Avatar
Not so much a mod
DW wanted more space when preparing meals. I came up with this folding shelf that sits in the space where the overhead mattress folds. Easily removed folded and stored in the basement when not needed. Very light weight.
ID:	98172   Click image for larger version
ID:	98173   Click image for larger version
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 01-22-2016, 12:22 PM   #274
Very nice!
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 01-22-2016, 01:48 PM   #275
hkreck's Avatar
Neat idea and looks good too. Thanks for the pic's
Henry & Tena
hkreck is offline   Reply With Quote
Old 01-23-2016, 01:15 PM   #276
FIVE2MH's Avatar
I really like that idea! Thanks for sharing!!
FIVE2MH is offline   Reply With Quote
Old 01-29-2016, 03:16 PM   #277
I have several Winter projects going on our 2014 24R.
1. Replace kitchen faucet. The one it came with is an "el cheapo", and way too big for the single sink. Found a very nice Moen stainless "spot resist" that swivels out of the way against the wall. I also discovered the drain and both water lines were only "finger tight", and the drain was leaking. I also installed plastic PEX shutoffs on both lines and fastened the lines to the wall - they were just swinging 3-4 inches from the wall. (ALL PLUMBING should be fastened - after all, the whole thing is on wheels !)
2. Replace the heavy clunky glass shower door assembly with a new vinyl and aluminum one that bows out into the bath (7 inches) for more room. What a difference that makes!
3. Replace the sagging 2-string skylight blind with a 4-string blind that I already purchased from the dealer.
4. Fixed the noise coming from the LED light wire-nuts over the dinette table that rattle on the underside of the paneling when going down the road. I removed the LED light receptacles, pulled the wire through (there is a lot of slack), and wrapped the wire nuts with bubblewrap. Then just pushed everything back up and screwed the lights back on.
5. Replace the el cheapo entry door light with a black LED motion light (from Starlights). Very cool. It matches all the other black items on the 24R.
Old 01-29-2016, 03:38 PM   #278
RedLdr1's Avatar
This is on my list as well... Do you have a link to the replacement you are using?
Wayne and Christine
2019 R-Pod RP-180 10th Anniversary Edition
2018 Ford F-150 SuperCrew Lariat FX4 (4X4) 3.0L Power Stroke Diesel
RedLdr1 is offline   Reply With Quote
Old 01-29-2016, 03:54 PM   #279
Call Traico to order the Shower Door
I initially gave Traico my dimensions and he told me what he had that would fit. I wanted the dark bronze to match everything else, but all he had was a stainless model. I don't know if I have a 'model', but I'll look this weekend.
Here is the original thread with pictures -
https://www.rv.net/forum/index.cfm/f...print/true.cfm
Traico Marinoff
Parts & Warranty
Shower Enclosures America
800-536-7324 x3110
Fax: 909-605-7793
Old 01-29-2016, 05:47 PM   #280
RedLdr1's Avatar
Thanks, that's is the vendor I'm considering. Bclemens mentioned them in a post and attached a .pdf from SEA showing this setup.
Wayne and Christine
