Originally Posted by DaveJordan
Once again, it looks like you've done a great job!
I've been thinking about the shower door as it's not too much money (I think? Did you order direct from SEA? And (if you don't mind) how much was it?)
As for the rail cuts, it looks like the ends of top rail are covered by the mounts? If so, the cut wouldn't make much difference? I didn't see similar mounts on the bottom rail, but they might be there...
Dave
I will have to locate my invoice - I purchased it from a business in Indiana - I know that SEA is a Canadian company. I believe it cost $130 - which included shipping.
The top rails are covered at each end, but you still want a good cut, as it has to fit the curve in the covers, and a bow is always harder to fit. A bad cut might not fit the curve correctly. The bottom has no covers, so you want a clean straight cut there too.
Also - I bet it can't be 3 pounds total - cutting a lot unnecessary weight.
Hope that helps !
