Old 08-09-2013, 08:56 PM   #61
Sandiegodoug's Avatar
I have 2 fantastic fans and love them. I want to replace the bathroom one too
They really air out the unit but are a bit noisy at high
Sandiegodoug is offline   Reply With Quote
Old 08-10-2013, 09:22 AM   #62
hkreck's Avatar
I have two of the fantastic fans also and like them very much. Personally I like having a fan running at night helps block out some of the outside noise.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 08-10-2013, 10:24 AM   #63
NELA
Weezer's Avatar
Congrats on the Flex Steel sofa!
Flex Steel is the Kenwood of furniture.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 08-12-2013, 10:07 PM   #64
Just installed a BodySpa shower head, works great at very low pressure, however my valve does not totally turn off the water. I get a small stream. Is this normal? Larry
13larry is offline   Reply With Quote
Old 08-13-2013, 03:49 AM   #65
Yes, that is normal from what I have read. I have mine installed, but haven't officially used it yet. Will tomorrow when we head out. But it does have a slight stream when the valve it turned off.
DebbieMH is offline   Reply With Quote
Old 08-13-2013, 08:23 AM   #66
2018 FR3 30DS
shower head cutoff
Check this...Danco 89171 shutoff valve. Put this on your Oxygenic shower head to turn water off/on...available on Amazon, Home Depot, Lowes, etc.
I use them on regular showers at home.
Slow_movin is offline   Reply With Quote
Old 08-13-2013, 08:37 AM   #67
Fulltime family RVer
Agreed. I have the same thing installed.
ependydad is online now   Reply With Quote
Old 08-13-2013, 06:35 PM   #68
MaxxAir fan installed. Fantastic! Off to Houston tomorrow.
Old 08-13-2013, 08:45 PM   #69
Taylorgso's Avatar
Don't know anyone with the MaxxAir, but lookup tells me it's a nice piece of work. I installed a Fantastic fan with thermostat and remote last month. I keep it set to run when the coach is parked under the shed... crack a window or two, and really keeps the coach from getting that musty smell. Looking forward to using it to keep cool this fall, instead of running A/C!
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 08-18-2013, 12:21 PM   #70
2012 Solera
Just added a switch for the steps mounted about 2/3 of the way up the left (hinge) side of the door. Intent is to disable auto step deployment when I'm parked next to a curb (or similar situation). I cut one of the wires to the magnetic door opening sensor at the lower left of the screen door (hinge side) and wired the switch in series with the sensor. If in doubt of clearance, we can shut off the switch, open the door, look, if sufficient clearance, turn the switch on and deploy the steps.
JLeising
2012 Solera "S"
Calif SF Bay Area
