Forest River Forums
Sunline User Photos
Old 12-14-2011, 09:44 AM   #1
Motorhome batteries
I have a 2012 Solera with two batteries installed under the steps. I do understand from our walk-through that they are not maintenance-free and the cells need to be checked and filled if necessary. However, I have just winterized the unit and plan to cover it for the winter months. I always removed the battery from my pop-up camper and brought it inside. What is recommended for motorhome batteries??
Thanks for the help - I appreciate all the comments on this forum!
RSolera is offline   Reply With Quote
Old 12-14-2011, 11:54 AM   #2
cfsoistman's Avatar
Unless you have it plugged in so the charger would keep them charged I would remove them. Even if it's plugged in you'll still need to keep an eye on them so they have proper fluid levels.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 12-14-2011, 05:55 PM   #3
Mountainmanbob's Avatar
voltage loss per month - 1% to 15% per month
if you wish to leave them in the unit
take all leads off + and -
the - may be over kill ?
fill with distilled water to proper level
apply a low amp charge
until battery reads 12.6 or higher
if you can do this every let's say month
while in storage -- should be good
if not
possibly bring them home to your garage
for storage and occasional topping off
All Lead-Acid batteries supply about 2.14 volts per cell (12.6 to 12.8 for a 12 volt battery) when fully charged. Batteries that are stored for long periods will eventually lose all their charge. This "leakage" or self discharge varies considerably with battery type, age, & temperature. It can range from about 1% to 15% per month.
Mountainmanbob is offline   Reply With Quote
» Online Users: 610
106 members and 504 guests
4bnabird, Al Fresco, backin15, Barney1, biggie, bikendan, Bill_C, bradyashton, Cafjackracing, Canuck_Doug, caper, cbj, CC Steve, ccyake, chadvc, COcamper, cpope84, crazn, cyclepuck, dashonthedash, dasimser, datadr, daw592, dawg82, demoore, DGrissom, Dodge Guy, DonG, donn, dunnnc, dware1962, ERRT, etbt1216, fast murray, feerobk, Fire Instructor, Fitchy, FreedomTracker, frfan, GASPEDDLER, gator man, Go Camping, Goomph, herk7769, Iggy, imabmwnut, ironj, jd-ford-hd, JDWeir, jimh, jmlocke, Jnied, Jo54, JoeR, JoeyO, jonnys_walkers, jrat, jsutherl, KKapa, Kman9936, KRS, kvn4th, kz08h5, lami, LeadPoop, lowbubba, low_flyer, lurch, MikeFletcher24, Mpjduff, Mpwelch50, Msaunders, mtofell, N3HCP, Namchief, newtsx3, nightcrawler, nrcamp, OffPavement, pappcam, pbrackney, pchrcane65, polkatronron, PrairieBoy, QDog, racerx, RalphieG, ret2006, RichardE, robert elling, Rsgtivr6, sandys, seatosea, Senor, snjparham, Sockman, softwarejoe, stevengb, tabkld93, Terier, Triguy, troyt, unhcharger25, wayne anthony, Whiteknight, william.migues
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
