Old 07-21-2014, 04:19 PM   #11
Mikegjax's Avatar
Try this:
Air-Flexx Valve Extensions
Should be 75 and 145 mm
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 07-21-2014, 04:57 PM   #12
hkreck's Avatar
I contacted Myers about these and was just informed the most popular are the 7 1/4" or 185 mm, I got the 5 11/16" 145 mm for the outside duels and already have the 7 1/4" for the inside duel
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 07-23-2014, 10:57 AM   #13
bclemens can you answer?
I see two different answers from Mikegjax and Hkreck on which lengths of Air-flexx extensions to buy. I have the stainless steel wheels. Can you advise which lengths Forest River recommends?
tommyb is offline   Reply With Quote
Old 07-23-2014, 11:28 AM   #14
hkreck's Avatar
tommyb
I have the 7 1/4" Air-Flexx on my rear duels which came from the factory that way. That's 7 1/4" on the inside and outside duels. I'm replacing the ones on the outside duels with the 5 11/16" to make them a little shorter but staying with the 7 1/4" for the inside duels. Something I noticed on the Air-Flexx web site is they state DO NOT secure the extensions to the wheel. Just FYI there.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 07-23-2014, 12:15 PM   #15
Originally Posted by hkreck View Post
tommyb
Hreck, wheel or wheel cover? I'm guessing wheel cover in the event it seperates from the wheel, and takes the air-flexx, and valve stem with it.
Old 07-23-2014, 12:19 PM   #16
Mikegjax's Avatar
That is interesting! Mine came with 5 11/16 (145) and 2 15/16 (75).
2014 Solera 24R
USN Retired
Old 07-23-2014, 01:54 PM   #17
hkreck's Avatar
Still kickin
According to the info on their site it shouldn't matter if the air-flex goes off with it as there's no pressure or air in the extension until you press in on the stem, However I could see your point about taking the valve stem with it. Any case I'm just going by what they stated.
Mikegjax
That's interesting I wish my had come that way make more sense than all four of them being the same length.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 08-08-2014, 01:47 PM   #18
To heck with extensions...
I decided to go with solid metal valve stems, instead of using extensions, as referenced by CaptDan and Taylorgso.
Spoke to Bill Falkenborg of yourtireshopsupply.com Phone is 800-300-2674. He was very knowledgeable and stands behind his product 100%.
The one that fits my Solera (2011 on 2011 Freightliner) is:
DL1SPFR Chrome Duallyvalve Kit with Front Stems
He also said that he would welcome the opportunity to send samples to Forest River for evaluation. Bclemens, are you listening? Give him a call.
Old 08-08-2014, 05:54 PM   #19
"GOOD FOR YOU"-As I have stated before:
Just a Quick Note, I had Stainless Steel "Extenders" installed on my tires for my first trip in my 2013 Solera 24S to hopefully alleviate any tire problems two months ago. Anyway, I had nothing but problems with the “Airless Extenders” from Orlando-Tucson-Albuquerque-Dallas-Canyon Lake-Orlando. The main problem was the extenders were vibrating off the rubber tire stems in the wheel well and leaking pressure. I ended up loosing an inner tire enroute. They were not one piece tied into the 16" steel tire wheel well. Now they are and I would highly recommend them. You can also install a tire pressure monitor with these at a later date if it meets your needs. Just some "Food for Thought." Good Luck and Happy Travels.
CaptDan is offline   Reply With Quote
