Old 09-09-2015, 10:57 PM   #21
Thanks for this suggestion. I will take it in immediately to Auto Zone and have it checked with their scanner. There are no Mercedes Sprinter repair shops within 150 miles but Auto Zone is just down the street. Thanks.
Doug Michaels
2015 Solera 24W
Three big dogs
One wife
Two kayaks, One SUP
Bend, Oregon
Solera is offline   Reply With Quote
Old 09-09-2015, 11:12 PM   #22
Anacortesians
You're driving a low-powered, heavily loaded diesel truck. It ain't going to beat Corvettes away from the traffic lights and may have a hard time doing better than a transit coach.
You can spend a large amount of money trying to improve it or spend the money on fuel and CGs. We chose the latter.
Frank and Eileen
No longer RVers or FR owners
Old 09-09-2015, 11:14 PM   #23
Pod2Vibe's Avatar
That would only work if your CEL was on. (Check Engine Light)
I have driven several Sprinters in the past, in addition to my Solera.
Also my FedEx guy has one and FedEx does not manually shift.
All have operated normally in D Drive. You should only "have" to use the manual shift feature if needed for downshifting, etc.
I have heard mention of the issue with yours over there.
Good Luck!
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 09-09-2015, 11:33 PM   #24
Left Coast
I've seen codes set without turning on the light
Old 09-09-2015, 11:56 PM   #25
Pod2Vibe's Avatar
On an MBS?
Pod2Vibe
Old 09-10-2015, 04:54 AM   #26
MarsMan's Avatar
I have the 3500 MBS chassis under my 24J and have been watching this. I have driven mine in "D" and with manual shifting. I have not noticed any difference in fuel economy (20 mpg). In manual mode I found I never went above 4th. she seems more responsive on grades. I only went to D when I was at 65mph or greater and on the flats. On take off, if she is cold I find her sluggish in "D" or in manual. I typical still use manual for a while and then may go to "D". I play it by ear. when the DH drives it, it will be in "D"
I just ordered an ultragauge to monitor trans temp, LOD, etc
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
MarsMan is offline   Reply With Quote
Old 09-10-2015, 10:28 AM   #27
mike.t's Avatar
Don't quite understand Bob. The computer picks up something from a sensor sense's a problem stores a code and makes no one aware?
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 09-10-2015, 10:55 AM   #28
Left Coast
I've had late model stuff not turn light on .....but code stored either as a 1 time event, or as a pending....no light.......lots of fun to trouble shoot. If what is caus'n no upshift, such as govornor ( now days electronic sensor),or wire loom.or connections, alternator creating leakage into wire loom....some freaky stuff like that.....not everything will set off the light...I've learned by the school of hard knocks.
Old 09-11-2015, 10:12 AM   #29
Thanks for all this info about the problem I originally stated. I will try to get my Solera to AutoZone and have it scanned for a code. So far no light appears on the dash to concern me. No problem with power when I shift down manually but that is the issue here. I will keep you posted after Auto Zone.
Doug Michaels
2015 Solera 24W
Three big dogs
One wife
Two kayaks, One SUP
Bend, Oregon
Old 09-11-2015, 11:38 AM   #30
Mikegjax's Avatar
Second year and have had no problems using drive for all normal operations. Acceleration is very good for a vehicle of this weight and size engine. Actually impressive. I will manually down shift occasionally when climbing or descending steep hills. It is an automatic and should be driven like one IMHO.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
manual, power
