Old 03-20-2015, 07:06 PM   #21
Originally Posted by bob caldwell View Post
Used to fill heavy equipm tires back ib the day, wjth Calsium (?) and water. Little pump, took forever!
Calcium Chloride & water was also used in tractor tires for ballast when plowing, etc.
Old 03-20-2015, 07:11 PM   #22
Left Coast
Dirt farmer?
Old 03-20-2015, 08:12 PM   #23
Dirt farmer?
Not me, but my grandpa was until he retired at 96 and died age 98.
Old 03-20-2015, 08:47 PM   #24
Left Coast
Just goes to show you, us old dudes found out early, if you wanted to do anything in life and not starve to death, the JOB was everything. To bad typing class and grammer were subjects weren't paid much attention to!.....
Old 03-21-2015, 08:57 AM   #25
Originally Posted by wmtire View Post
I'm sorry, but there are several things here, where water in a tire is concerned that I have a different opinion on, and experience thereof....and you did mention tire specialists in your post.
Water inside a tire will cause high speed imbalance, as will fix-a-flat. I run across this almost everyday in my business. I have dismounted many, many a tire to remove the water and/or fix-a-flat that is causing imbalances.
Here is my thinking too. Although water is used as a coolant in automobile systems, I think the functions of a radiator and heater core as the heat exchangers in an automobile have been neglected to be taken into account for. A tire will not have a heat exchanger, thus an outlet for the water to disperse heat once it has reached the temperature of the tire internally.
For good understanding ( I am Dutch ) you write that to much liquid water cources disbalance , wich can cource blowing tire ( fix a flat??) .
The amount of water I think enaug is to go over to gas when higher temp.
this is about 18 gram so about 0,040 lbs ( converse yourselfes to gallon or whatever), then at 100degr C/212degr F all the water would be as gas .
But I only mentioned tire-specialists for that they can confirme the rimm inside the tire is not coroded . Can you confirm this or do you have other experiŽnce?
I am still not totally shure about water , like how much energy it absorbes as gas to rise 1 degr in temp For oxigen and nitrogen its about 20Joule/Moll/degr Kelvin/celcius.
When I use water 1 calory =4.2Joule a gramm .
1 moll is 18 gramm so 18 x 4.2= 73.6J/moll/degr K but mayby as gas it aborbes lower energy . there is though sertainly a difference between when pressure stays the same , and when vollume stays the same( as is in tires), 2nd is lower energy absorbtion for 1 degr K.
But I stated my story like i did , so Nitrogen lovers must try to demith it.
Now the Nitrogen-lobby state some arguments that we have to demith, so fight it with their own weapons.
jadatis is offline   Reply With Quote
tire, tires
