10-10-2015, 10:44 AM
No Anode in Water Heater
When I drained my water heater for winterizing I found there is no anode, just a plastic plug in it's location. I questioned the dealer and they said because the tank is glass lined so no anode rod is required? I have never heard this before because I know residential water heaters are glass lined and fail quickly once the anode rod is depleted. Do you folks have a just a plastic plug or is there an anode rod?
10-10-2015, 11:05 AM
Atwood = has no anode
Suburban = has anode
Check your model
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
10-10-2015, 05:14 PM
The Solera comes with Atwood and no anode is "normal"
Pod2Vibe
Magnetic 2019 Isata 5 30FW 4X4 (arrived 2/15/19)
TOAD: 2014 Fiat 500 Abarth
2015 Solera MBS 24R - Hellwig/Sumo Equipped, Sold
(Sold the Vibe TT, as well)
10-11-2015, 10:22 AM
I think you need to check the year on the Solera mine's a 2013 and has a Suburban with anode.
Henry & Tena
10-11-2015, 10:31 AM
Just put an anode in there and call it a day?
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
10-11-2015, 10:38 AM
Citrus County, Fl.
I had a 31' Terry for 15 years. Just drain and flush every fall and no issues.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
10-11-2015, 10:39 AM
From what bclemens has stated, they changed from the suburban to atwood around 2015.
http://www.forestriverforums.com/for...elp-82884.html
2011 Flagstaff 831 RLBSS
10-11-2015, 11:04 AM
Dealers are DUMB as a general rule.
Specific ones may be the exception; I just haven't met one yet.
Aluminum Tanks do not need Anodes (Typically Atwood).
Iron ones (glass lined or not) (Typically Suburban); DO.
The interior glass does reach the fitting intrusion points or the torque of tightening the fitting would crack the glass. The glass is there for longevity of the boiler due to the thinness of the tank walls for weight reduction. They still will rust out quickly (at the fittings) without an anode.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
10-11-2015, 11:08 AM
An aluminum anode in an aluminum tank is wasted money.
A Magnesium anode might be electrically helpful but result in Magnesium Oxide nodules from the anode decay in the floor of the tank. Why add another metal to your drinking water?
10-11-2015, 11:48 AM
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
I agree with Acadianbob,,,,,,,I've always put an anode in all of my heaters. They decompose over time....does that tell you something? Herk7769 ...so you drink your hot water?
10-11-2015, 11:57 AM
The lite has an Atwood, I would consider it a waste of money and my time to install an unneeded anode.
10-11-2015, 12:54 PM
You must like buying water heaters that keeps the lime from building up on everything inside the heater!!!!!!!!!!!!!!!!
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
10-11-2015, 01:06 PM
Opening the cold water tap while on the water pump will drop the system pressure until the pump cut in pressure. This will draw water from the bottom (inlet) of your hot water heater into the cold water pipes every time. You are going to drink, brush your teeth, or make your coffee with that water at some point.
Just saying...
The anode does not prevent Calcification; it prevents corrosion (rust) of the steel tank. The heat is what causes calcium deposits as the dissolved calcium in your water is precipitated out of solution at the heat source.
That is why you need to decalcify your coffee maker. The electric heater causes the calcium to be deposited on the heating element.
10-11-2015, 03:11 PM
Great info Herk.
The OP has a plastic plug on his WH which typically means Atwood, so rust is not an issue.
I would assume it was a recently purchased Solera or other MBS since they are a newer member and it is posted on the Solera forum, but they do not state the year of the rig, either.
Pod2Vibe
10-11-2015, 03:13 PM
https://www.google.com/?gws_rd=ssl#q...v+anode+rod+do
10-11-2015, 07:18 PM
Yes, the 2015 has an Atwood and no anode is needed. In fact, I highly recommend you do not put one in. I had an Atwood in a previous RV and a service guy stuck an anode in. When I tried to remove it six months later it would not come out. I called the service manager and he said one should have never been installed because the metal on the anode is different than on the hot water heater and (now I will likely use wrong terminology) they "melded" together.
He had the original service guy remove it, telling him if he damaged the water heater he was paying for it. Took the guy awhile but he got it out. Suspect he won't do that again. And I certainly won't!
10-11-2015, 07:29 PM
Originally Posted by Pod2Vibe
Great info Herk.
That was in response to the post made by Dicky1243.
10-11-2015, 07:34 PM
That is actually a fairly accurate description of what happened; aluminum to aluminum under pressure can cause the mated surfaces to bond making the seam tend to disappear over time. (atoms of one item join at the molecular level to the atoms on the other item becoming one lattice).
The tighter the connection, the higher the pressure at the threads and the more likely for the aluminum to try and meld together.
10-11-2015, 09:35 PM
I've never had that problem....probably because I pull my anode out every six months and pressure blow the lime build-up out the hole. I also use teflom tape to keep the threads from allowing galvanic corrosion.
10-11-2015, 10:18 PM
My old trailer had an Atwood water heater no anode used the water heater all the while, the trailer was a 96. Never plugged up still worked when sold last year, next year that would be 20 yrs old.
Think about things before you do them make life easier not harder.
