Old 09-03-2015, 11:57 AM   #1
no brake light out on 7way
All rear tailight work except brake light output at 7way trailer plug.i have brake input to converter.i have installed a new converter and the resistors measure 6 ohms.anyone have wiring diagram. 2014 solera with led tailights
arch2160 is offline   Reply With Quote
Old 09-05-2015, 11:13 PM   #2
Hmm. Not sure what part of a wiring diagram you're looking for... As far as I know, the Solera 7 way does not include a separate brake light output. Some (all?) brake controllers use the combination of both left and right turn signals to indicate brakes on. (So they probably think four way flashers are brakes going on and off...).
Some wiring diagrams have been posted (for recent R and W models, I think) but I don't think they include details of the 7 way connector as that is run largely by a separate controller which is supposed to isolate the Solera wiring from the toad wiring...
Dave
DaveJordan is offline   Reply With Quote
Old 09-21-2015, 01:41 PM   #3
I had this happen. You have a fuse blown. The fuse panel is located aft of the water pump/filter (in the same compartment). After replacing the fuse, use silicone to seal the where the wires go into the connector on the bumper. Water gets in there causing the fuse to blow. Good luck!
barnbnb is offline   Reply With Quote
light, brakes
