Old 04-03-2013, 11:15 PM   #1
No Kitchen or Living room lights
2011 Solera
The lights that operate off of the central control panel marked Kitchen and Living Room do not function. I have tried the switches on the fixtures with the control switch in both on and off positions.
Checked for 12 V on both sides of all fuses in the converter.
Pulled control panel and have 12 votls at the common wire tying the Kitchen and Living Room switches together.
Tested Kitchen switch and it appears to open/close properly.
Any Ideas? Is there another switch somewhere I am missing?
Are the grounds for ALL of these fixtures tied together and possibly loose? Where would that tie point be?
Is there a coach wiring diagram available?
cousin01 is offline   Reply With Quote
Old 04-03-2013, 11:37 PM   #2
Iggy's Avatar
Do you have 12 volts any place in the rig?
Bathroom lights?
It just may be a wire came loose at the panel fuse.
Don't forget that an open ground wire will do the same.
Hope this helps a little
Iggy is online now   Reply With Quote
Old 04-04-2013, 09:29 AM   #3
ALL other 12 v functions fine. Even have 12 volts to the switches.
Old 04-04-2013, 04:36 PM   #4
GM
bclemens's Avatar
could all those bulbs have burned out? Did it suddenly happen?
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-04-2013, 04:38 PM   #5
TURBS's Avatar
My thought to.....
But that would be crazy right?
Then again..........
Old 04-04-2013, 04:38 PM   #6
AquaMan's Avatar
Possible surge through the lights could have blown all the bulbs. Pull them out and test bulb and/or socket for power
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 04-04-2013, 04:51 PM   #7
Phat Phrog Stunt Crew
awwall's Avatar
Since you have 12 volts at the switch, you may have lost the ground. Can you check from a light fixture to a chassis ground and see if you have 12 volts? If you do, you have either blown bulbs or have lost the ground to the fixtures.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 04-05-2013, 03:34 PM   #8
I will check bulbs and see if I have a ground FROM the fixture to chassis.
Guess there is no overall wiring diagram available, right?
Old 04-05-2013, 04:30 PM   #9
TURBS's Avatar
You are correct ...... no wiring diagram available .
turbs
Old 04-05-2013, 04:53 PM   #10
puff's Avatar
I would be checking for power and grounds at each fixture, like the rest said. Short of that is it possible that the on/off switches were turned off on the fixture itself..?
I might even pull the light fixture off the ceiling and check the wires coming in.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
