02-18-2017, 12:00 PM
No Water to Toilet
2014 Solera MB
With beautiful weekend here in VA I decided to dewinterize. No issues until I got no water coming into toilet. I did get small amount of antifreeze and some air coming through the line.
After that nothing.
All faucets and the shower ran clear after a bit of air etc...
Any help would be appreciated
02-18-2017, 12:10 PM
Have you tried relieving the water pressure from the entire system and then pressurizing again?
Bruce
02-18-2017, 02:43 PM
Relieve pressure and dismantle connection at back of toilet, most likely debris plugging inlet.....
https://www.google.ca/search?q=no+wa...G4KjjwSC0K7gCw
Fonzie
02-18-2017, 02:52 PM
Originally Posted by fonzie
X2
02-18-2017, 06:56 PM
I'm not much of a handyman. I will try this when I get home tomorrow.
Exactly what do you folks mean when you say relieve pressure ?
Kidagn
2014 Solera R
02-18-2017, 07:28 PM
Turn off water pump or disconnect from public water and open a faucet until water stops. Then reconnect and try again. Probably crud from water heater clogging valve.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-19-2017, 01:12 PM
No Water to toilet
I had the exact same issue. If you have been anywhere before then you may have encountered the same issue. One of the parks I stayed in had an incredible amount of silt in their water and I did not know that until I tried using my holding tank water and nothing came out at the toilet. I unscrewed the fitting at the back side of the toilet, after ensuring the pressure was relieved, and found the screen was packed with sand/silt. it took a few times of flushing my holding tank and cleaning the screen on the toilet water inlet to clear it but that did the trick. Hope this helps.
Dano
02-19-2017, 02:22 PM
I had that happen last year, I took the fitting loose at the back of the Torret scraped the junk loose with a stiff brush then vacuumed it out , not to hard as there's a screen in there to keep junk out of the valve
02-19-2017, 02:54 PM
I put a plastic grocery bag around the area to catch extra water and use a keyboard spray to clean of the screen inside the connection.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
02-19-2017, 03:17 PM
Drink more water, ha ha, there plenty of solutions, most likely is debris in water lines.
DJsFolly
02-19-2017, 06:04 PM
Thanks to all!
Kidagn
2014 Solera R
02-20-2017, 09:15 PM
Is there a filter installed in your on-board water filter container? Some folks bypass it and use the disposable in-line water filters available at Walmart or other retailers. Using a filter can go a long way in avoiding issues such as this.
Mark & Susan
Former MBS 24R and 2401W Owners
Just recalibrating our camping set-up for now!
02-21-2017, 01:15 AM
Retired Aerospace Engr.
No water to toilet
The link furnished within this thread yields more threads on this subject. Check out the forth one titled No water to toilet...I'm confused. - Forest River Forums.
It is dated Nov 27, '16. My response is on the second page under user DUBLBZ. This will not always be the problem, but is in the probability category of around 90%.
02-22-2017, 09:40 AM
No water to toilet
Many thanks DUBLBZ!
Kidagn
2014 Solera R
02-25-2017, 11:58 AM
No water to toilet
Folks,
okay I finally had an opportunity to work on this issue of no water to toilet in 2014 MB Solera.
I have disconnected the water line coming in.
Please see attached picture... where is the filter I need to clean and how do I get to it. Again, apologize as I am not much of a handy man.
Kidagn
2014 Solera R
02-25-2017, 12:19 PM
Originally Posted by kidagn11
Folks,
There is a plastic push in fitting on the back of the flush valve. Pop it off and there is a screen that will be plugged. I have attached the manual for the Dometic toilet that I have, hopefully yours is similar.
2015 335DS
02-25-2017, 01:05 PM
No water to toilet
Thank you very much
