Old 02-23-2012, 11:59 AM   #11
mckirby50's Avatar
Originally Posted by George
I had the same problem with the radio i.e. no reception. The dealer found the antenna was located between the cab roof and the overhang. It was also not grounded. The dealer had an audio store put an electronic antenna inside on the windshield. Works great and they didn't drill my fender for an outside antenna that would have led to rust.
I have the backup camera and it has a volume control, but I can't get any sound.
I guess the camera itself should have a mic ( haven't checked) right?
mckirby50 is offline   Reply With Quote
Old 02-23-2012, 12:10 PM   #12
mckirby50's Avatar
We have the same backup camera system and have the volume turned all the way up but still get no sound! I guess the camera has a mic built in (haven't checked yet)
That would be nice to get working, but have lived without for a year.
No trouble with the radio, but do notice the brakes could feel firmer. We have a 2012 model and have nearly 7,000 miles on it now.
Really ready to get back on the road for a few trips. Next planned trip will be June, going to Panama City Fl ( St Andrews State Park). But will be hitting some closer lakes in Oklahoma till then.
Old 02-23-2012, 01:43 PM   #13
GM
bclemens's Avatar
Depending on the camera at one time we stopped powering the audio because even at low volume there was still noise. If you look underneath the driver side dash panel (you have to pull the panel down and the box is above the steering column area)...there should be a "multiplexer" (little silver box). If you hook the "blue" reverse wire up to that box it will power the audio in reverse.
This is assuming its the same model of course...but worth a try.
File Type: pdf RVS Systems Rear View Camera RVS-770616N.pdf (495.3 KB, 24 views)
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
