Old 09-19-2015, 07:31 PM   #1
Non skid rubber pad on the step up to the cab
I encountered high winds while traveling and noticed the rubber pad that's affixed to the step-up disappeared. Where would I find a replacement? I am not sure of the proper part description. Any input would be appreciated.
jcinca
012 solera
jcinca is online now   Reply With Quote
Old 09-19-2015, 07:38 PM   #2
RedLdr1's Avatar
Do you mean the black rubber mat lightly glued to the cab step? If so the easy way will be to visit Home Despot or Lowes and get a couple of feet of bulk rubber mat to cut to fit. I'd pull off the passenger pad to use for a template to cut new mats. Clean the step areas good and get some serious adhesive to put the new ones on with...
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 09-19-2015, 07:48 PM   #3
hkreck's Avatar
After mine came off the second time after using a very strong adhesive, I use some small screws to hold mine on. Put two on each side of the mat along with adhesive to hold the center.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 09-20-2015, 03:54 PM   #4
Are you talking about the adhesive anti-slip material attached to the retractable step? You mentioned high winds, so I assume it couldn't be the inside rubber stair tread coverings, correct. If you do mean the non-slip covering on the retractable stair step, those I have seen on amazon . Amazon.com: 3M Safety-Walk 7768 6 by 24-Inch NA Reflective Tread: Home Improvement
I'd shop that item for price. Maybe CW carries it, but they gouge pretty good. If this is what your asking about, and find it cheaper, let us know.
