Old 02-28-2016, 09:24 AM   #11
BendOrLarry's Avatar
Ultragauge works with diesel rigs as well. Look at pre-sales FAQ on their website.
http://www.ultra-gauge.com/ultragauge/
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 02-28-2016, 11:40 AM   #12
What model Scanguage is best for the MBS.
Dogpa
2016 24R
John Craft
dogpa
2016 Solera 24R
dogpa is offline   Reply With Quote
Old 02-28-2016, 03:14 PM   #13
RedLdr1's Avatar
The ScanGauge II is what I'm using. The "D" version is for diesel pushers with a funky interface cable. With a MBS you need a standard OBD2 connector, not the "D" style. The "E" would work but it is too stripped down for what I wanted.
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is online now   Reply With Quote
Old 02-28-2016, 03:27 PM   #14
Thanks RedLdr1. Something else for my shopping list.
Dogpa
John Craft
dogpa
2016 Solera 24R
Old 02-28-2016, 07:36 PM   #15
Not sure how you are monitoring transmission temp on the sprinter. Parameter is not available on my model year.
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 02-28-2016, 08:22 PM   #16
I'm going to order the Scangauge II tomorrow. Do you guys make a permanent cut out in the door that covers the OBD port or just leave the door off? Also, I was thinking of mounting right between the speedometer and tachometer, what do you all think about that (and where does the extra cord go - somewhere under the dashboard I presume)
adinallo is offline   Reply With Quote
Old 02-28-2016, 08:38 PM   #17
RedLdr1's Avatar
I'm leaving the door off at the moment. I may cut the door if I find a cheap replacement on eBay. I have mine mounted between the speedometer and tach as it is the easiest to see with a quick glance for me...
Wayne and Christine
Old 02-28-2016, 08:45 PM   #18
davel1971's Avatar
Edge CTS is a great monitoring device that works in any vehicle that is OBD II. Very customizable.
David & Lynn
Old 02-28-2016, 09:21 PM   #19
Wayne, If you find a replacement door online and do not mind sharing, I would buy one too. I'll search and let you know if I come up with a replacement
Old 02-28-2016, 09:23 PM   #20
Dave, The Edge CTS looks like the top of the line unit. Is it less expensive than the $339 I saw at first glance?
