Old 03-06-2016, 03:55 PM   #31
Mikegjax's Avatar
Originally Posted by Mikegjax View Post
Here are the parameters for tran. temp. They were posted by "Rensho" on the Sprinter Source Forum
TXD 07E12130
RXF 032200000000
RXD 1808
MTH 00090005FFC6
Works great for me!
I have been doing some research on this XGauge parameter and supposedly it works on Sprinters from 2007 forward. If anyone tries it on 2007 to 2012 let us know how it performs.
When setting up your XGauge make sure to use an unused identifier. I believe TFT is used for another parameter.
Here is the actual source for the parameter.
https://www.scangauge.com/support/x-...odge-specific/
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 03-06-2016, 10:17 PM   #32
Originally Posted by BendOrLarry View Post
Is this the Captdan of PCT YouTube fame?
Sorry-Not the Guy! But you have me looking at YouTube, he is quite an adventurous person like all of us with our RV's.
CaptDan
2013 Solera "S"
CaptDan is offline   Reply With Quote
Old 03-07-2016, 08:40 AM   #33
BendOrLarry's Avatar
CaptDan
2013 Solera "S"
He had a great PCT experience and made some great videos.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 03-07-2016, 02:23 PM   #34
The 'automatic' odb2 device now texts me the check-engine message !
I programmed the 'Automatic ODB2' smart phone app to send me a text message AND an email of any check-engine events that may occur.
Whenever a check-engine event occurs, within a couple seconds my phone does a ble-bleep with a text message containing the actual event code and description. It also follows-up whenever it has Internet with a corresponding email.
I could actually have it email or text my mechanic directly if I wanted to ! The only problem is - I don't have said mechanic...
nusslejj is offline   Reply With Quote
Old 03-09-2016, 06:02 AM   #35
There is another solution
Originally Posted by adinallo View Post
I'm going to order the Scangauge II tomorrow. Do you guys make a permanent cut out in the door that covers the OBD port or just leave the door off? Also, I was thinking of mounting right between the speedometer and tachometer, what do you all think about that (and where does the extra cord go - somewhere under the dashboard I presume)
There are low profile OBD 2 extensions that allow you to close the door that covers the OBD port. I used this one and so far, so good -
Robot Check
KatanaPilot is offline   Reply With Quote
