02-28-2016, 11:37 PM
#21
Has anyone found an Edge CTS link that says it covers MBS?
02-29-2016, 12:40 AM
#22
Most of us have just taken the screws out of the OBD connector. It can then be pushed
up into the compartment with the cable attached
2011 Solera 235S
Freightliner Badge
02-29-2016, 12:42 AM
#23
Originally Posted by Mikegjax
I also use SCAN GAUGE II on my MBS RV. Set up XGauge to monitor trans. temp. along with normal parameters. Mounted on the steering column with Velcro that came with the unit. Very handy to view what is going on with the little diesel.
Mike. What xguage parameter are you using for trans temp?
2011 Solera 235S
Freightliner Badge
02-29-2016, 07:43 AM
#24
Here are the parameters for tran. temp. They were posted by "Rensho" on the Sprinter Source Forum
TXD 07E12130
RXF 032200000000
RXD 1808
MTH 00090005FFC6
Works great for me!
2014 Solera 24R
USN Retired
02-29-2016, 09:48 AM
#26
Originally Posted by adinallo
Wayne, If you find a replacement door online and do not mind sharing, I would buy one too. I'll search and let you know if I come up with a replacement
I'll start a new thread for it when I find some... I'm not going to pay M-B parts prices for a minor issue!
Wayne
2024 Sunseeker 2150SLEF / Ford E-350
03-01-2016, 11:26 AM
#27
I also have 2 cents to throw in to this thread
I am using the new 'automatic' ODB2 device. What is really cool is that not only can you connect your favorite smart phone app (like dash command), it also logs your travel geographically, your starts/stops, your mileage, gallons used (based on a pre-programmed price), etc., and keeps all your trips so you can compare and look things up. I put together an IFTTT recipie to upload my trips to outlook.com's onedrive for storage and sharing on the phone whenever the trip has completed, and the phone has internet.
Here is a link to a couple test trips I made with my car.
http://1drv.ms/22N1w8X
03-05-2016, 09:43 PM
#28
"Great Read"-Another nice to have addition for my 2013 Solera "S", I will purchase when I return from overseas by the EOM! Looks like Advance Auto is the way to go. "Thank You"
CaptDan
03-05-2016, 10:43 PM
#29
CaptDan
Is this the Captdan of PCT YouTube fame?
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
03-06-2016, 12:46 AM
#30
2007 WildCat 32QBBS
CaptDan
To all considering Scan Gauge II. You can Internet order from Advance Auto and pick up at the store in an hour, or have it shipped.
*Upon checkout, use promotional code " TRT30 " for a $48 discount. Final cost $112
03-06-2016, 04:55 PM
#31
TXD 07E12130
RXF 032200000000
RXD 1808
MTH 00090005FFC6
Works great for me!
I have been doing some research on this XGauge parameter and supposedly it works on Sprinters from 2007 forward. If anyone tries it on 2007 to 2012 let us know how it performs.
When setting up your XGauge make sure to use an unused identifier. I believe TFT is used for another parameter.
Here is the actual source for the parameter.
https://www.scangauge.com/support/x-...odge-specific/
2014 Solera 24R
USN Retired
03-06-2016, 11:17 PM
#32
Sorry-Not the Guy! But you have me looking at YouTube, he is quite an adventurous person like all of us with our RV's.
CaptDan
2013 Solera "S"
03-07-2016, 09:40 AM
#33
CaptDan
2013 Solera "S"
He had a great PCT experience and made some great videos.
Firestone airbags
03-07-2016, 03:23 PM
#34
The 'automatic' odb2 device now texts me the check-engine message !
I programmed the 'Automatic ODB2' smart phone app to send me a text message AND an email of any check-engine events that may occur.
Whenever a check-engine event occurs, within a couple seconds my phone does a ble-bleep with a text message containing the actual event code and description. It also follows-up whenever it has Internet with a corresponding email.
I could actually have it email or text my mechanic directly if I wanted to ! The only problem is - I don't have said mechanic...
03-09-2016, 07:02 AM
#35
There is another solution
I'm going to order the Scangauge II tomorrow. Do you guys make a permanent cut out in the door that covers the OBD port or just leave the door off? Also, I was thinking of mounting right between the speedometer and tachometer, what do you all think about that (and where does the extra cord go - somewhere under the dashboard I presume)
There are low profile OBD 2 extensions that allow you to close the door that covers the OBD port. I used this one and so far, so good -
Robot Check
