Old 08-14-2015, 11:35 PM   #21
Pod2Vibe's Avatar
MBS Tranny Temp Gauge
Originally Posted by Phinias View Post
Hay still kicking. Knowledgeable people have told me that none will moniter Coolant Temp or Tranny Temp. i am trying to discover a OBD II can reach those codes on a 2014 MBS
To reiterate, coolant temp works out of the box with the ScanGuage II on the MBS.
Just got Tranny Temp setup and working as a custom "xgauge" on the SGII thanks to Rensho on the Sprinter Source Forum. He's the man!
Here is the Tranny Temp programming code setup for the "xgauge"
TXD 07E12130
RXF 032200000000
RXD 1808
MTH 00090005FFC6
Just go into the setup for the SGII and find the xgauge setup and create a new gauge by entering the above codes.
Tranny temp runs about 10-15 degrees below coolant temp w/o toad, fyi.
Will pull the toad for a couple hours tomorrow in the 100 degree heat and see what I get.
Cheers to knowledgeable people
Pod2Vibe
Magnetic 2019 Isata 5 30FW 4X4 (arrived 2/15/19)
TOAD: 2014 Fiat 500 Abarth
2015 Solera MBS 24R - Hellwig/Sumo Equipped, Sold
(Sold the Vibe TT, as well)
Pod2Vibe is offline   Reply With Quote
Old 08-16-2015, 11:41 AM   #22
Phinias's Avatar
DEF
Good Info, thank you.
Does Scan Gauge 2 give DEF levels?
Phinias is offline   Reply With Quote
Old 08-16-2015, 02:12 PM   #23
Phinias's Avatar
Or oil pressure readings?
Old 08-19-2015, 11:43 AM   #24
Pod2Vibe's Avatar
Nothing yet on DEF level or OP.
There is CAT Temp so you can monitor regen which doubles the CAT Temp, during the process.
Just got back from a trip when towing. Tranny and Coolant temp maxed out at 227F when outside temp was 105F going up a grade.
Pod2Vibe
