Old 07-08-2015, 05:41 PM   #1
Obstructions in Floor
Are there any obstructions or wiring in the floor between the kitchen and sofa/dinette of the 24R? Or is it just the 3 layers of plywood. I want to attach these. They bolt through the floor and the anchor point is removable. To hold our bird cage while traveling.
Name:	ImageUploadedByForest River Forums1436395240.916276.jpg
DBTSolera24R is offline   Reply With Quote
Old 07-08-2015, 08:17 PM   #2
Be aware that if you puncture the floor you will need to seal that puncture from moisture intrusion from underneath the coach. Is there a way you can use the existing cabinets as your anchor points, using some other type fastener. Like building a small wooden base with maybe 2" sides that the cage can rest. Then teather the top toseveral anchor points attached to the cabinets to prevent tip over.
Old 07-15-2015, 07:03 PM   #3
Made a platform to put down in the step area and the cage is strapped to it.
