05-29-2015, 12:45 PM
Oil and filter
I was surprised to find our oil at Walmart today - for 23.88 for 5 qt! According to the label it fits the Mb specs 229.3, 229.5....also available in 1qt container for 7.88...
http://www.walmart.com/ip/Mobil-1-0W...5-qt./23636902
I need help in finding the right oil filter - any help? Would like to buy at Napa or Autozone...
Hans
05-29-2015, 12:47 PM
Call napa they will fix you right up on the filter.
When I managed a napa years ago they had Mobil but I doubt it's cheaper then wally world.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
05-29-2015, 02:41 PM
Is that Walmart oil rated for MB diesel? MB recommends ESP 0W30 229.52.
Also Advance auto carries the filter by Purolator that is made in Germany. Same filter as MB. Napa ran a sale on the oil a couple months back. Mobil 1 ESP 0W30 $5.99 qt.
2014 Solera 24R
USN Retired
05-31-2015, 12:30 PM
Mobil 1 0W-40 Advanced Full Synthetic Motor Oil, 5 qt. - Walmart.com
Hans
Ok, here is the skinny on this topic. First, DO NOT use that oil in your sprinter. The MB spec you need is 229.51 or the latest spec 229.52. They have discontinued the Mobil 1 ESP formula M 5w-40 and have replaced it with mobil 1 esp 0w-30. Also my research turned up MB brand 5w-30 which states it can only be used in a sprinter. If you use non "esp" mobil branded oil, you risk clogging your DPF diesel particulate filter, and I suspect you run the risk of engine warranty issues as well. Unfortunately, since there are only about 25,000 sprinters sold each year, neither wally world, advanced auto, autozone, etc. carry it as an on the shelf item. Hope that helps. DIYers can save an easy $150 bucks, doing it yourself.
05-31-2015, 12:42 PM
His MH is a 2013, warranty an issue?
Would he not be better off using the oil his manual says?
05-31-2015, 01:47 PM
100,000 on the emission system. Need to use Mobil 1 ESP 0W30 or equivalent.
2014 Solera 24R
USN Retired
05-31-2015, 02:15 PM
05-31-2015, 05:42 PM
Other Approved Oil
Another 229.51 approved oil is available from Amazon at an attractive price:
http://www.amazon.com/dp/B00KQEHHPG/...HI5S3OMX&psc=1
It is
TOTAL 188058-3PK Quartz INEO Long Life 5W-30 Engine Oil - 5 Quart (Pack of 3)
I think you can also get MB OEM oil filters from them.
Greg
05-31-2015, 07:01 PM
05-31-2015, 07:27 PM
Originally Posted by Still Kickin
This looks to be a chinese knock off.
The Alibaba link identifies this as a product of France. The approval 229.51 indicates that this specific product was approved by Mercedes for the OM642 engine. I have always used Mobil I oils in the 5 other Mercedes automobiles that I have owned, but will be happy to use any products approved by the excellent Mercedes engineers.
Greg
05-31-2015, 09:33 PM
Greg
Duly noted. However, upon further research, MB recommends Mobil 1 0w-30 which now carries the next level cert., being 229.52.
They state; "MB 229.52 Oils meeting this specifications must have lower ash content, at least 1% better fuel economy compared to the requirements of MB 229.31 and MB 229.51 and better oxidation stability for biofuel compatibility. Can also be used where an MB 229.31 or an MB 229.51 oil is required. Just like MB 229.5 and MB 229.51 this spec requires a long life oil."
I like this oil better for these reasons: 1. lower ash content. 2. better when biofuel is used(sometimes you can't avoid buying that crap) 3. better fuel economy, even if only by 1%.
just sayin'
Remember when life was easier!
06-01-2015, 07:41 AM
Well - that forum prevented me making a mistake. I did not see the difference of 292.5 vs 292.51 - thanks for the replies!
One thing I do not understand is what does oil have to do with fuel or fuel filter? It should never be in contact with each other? Maybe somebody can enlighten me....
06-01-2015, 08:21 AM
Some oil even, though miniut amounts does get into you exhaust and the wrong additives could damage the particle filter. Also the turbo charger requires the correct spec.
2014 Solera 24R
USN Retired
06-02-2015, 11:12 AM
Napa has Mobil super synthetic oil on sale $3.99 per qt. 6-1-15 thru 6-30-15
112908 0w30
112911 5w20
113938 530
112917 10w30
I see they have valvoline motorcycle and atv oil on sale to.
740 10w40 motorcycle $5.19
743 20w50 motorcycle $5.19
749 10w40 atv $4.49
TURBS
2011 32bhok Sabre
06-02-2015, 05:14 PM
112908 0w30
112911 5w20
113938 530
112917 10w30
749 10w40 atv $4.49
TURBS
2011 32bhok Sabre
They have Mobil 1 ESP X1 0W30 for $5.99 Qt. Just ordered 3 cases.
2014 Solera 24R
USN Retired
06-02-2015, 07:59 PM
Good points, Kickin'.
I'll be jumping on the NAPA sale too.
Greg
06-02-2015, 09:36 PM
I stopped at the Mercedes dealer last week and wanted to pick up a couple quarts of there oil. This is what they gave me. Cost under $10 per at.
Did the dealer provide the right oil?
Jon
In the end, it's not the years in your life that count. It's the life in your years. - Abraham Lincoln
06-03-2015, 07:10 AM
Has the correct spec. MB 229.52. Should be fine.
2014 Solera 24R
USN Retired
06-06-2015, 12:47 PM
Went to our local NAPA today and they don't have 0w30 ESP X1 Can you buy it online somewhere for $5.99 qt.?
2015 Solera 24R
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
