Old 08-21-2015, 09:05 AM   #11
RedLdr1's Avatar
Our 2105 has a maximum of 20,000 miles per M-B.
I discussed this with the local M-B Sprinter dealer and they suggest every 10K or annually. I'm going to go with their recommendation as the oil change, even at M-B, is still a lot cheaper than a engine rebuild or replacement! Add in potentially having to use B20 bio-diesel on a trip and it is good insurance in my opinion...
Originally Posted by Still Kickin View Post
But, bring a big wallet!
Especially since my DW really wants a M-B SL.... I think I'll be going alone on any service trips to our local dealer!
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is online now   Reply With Quote
Old 08-21-2015, 06:55 PM   #12
Hows that saying go, oh yeah, happy wife, happy life!
Old 08-21-2015, 07:07 PM   #13
Blackhat6mike's Avatar
That's like washing your feet and putting your dirty sox back on. Most of the contaminants that were filtered out of your oil are still in your filter. That's what filters do. Spend the very, very few dollars and do it right. IMHO
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 09-01-2015, 11:26 PM   #14
TARVIDSON
I just had my oil changed at 15,500 miles, about a year at the usual place I get oil changes with a Valvoline oil that Mercedes approves on their website. It cost $169, the Mercedes dealer wanted $400 and the Freightliner Dealer $379. Does anybody know how to reset the oil change notice on a 2014 Prism LE2150 without the steering wheel buttons. I have tried a method that was on a U Tube and it did not work, it involved holding down the lower button until it beeped and then following a procedure. I never get the beep. Any ideas?
TARVIDSON is offline   Reply With Quote
Old 09-02-2015, 03:32 AM   #15
MarsMan's Avatar
I did not get a beep on mine when I was playing with that screen. Wanted to see if I could scroll though. Which I could. I followed the instructional Utube someone on the Sprinter forum recommended. Other than the oil and filter anything else due at 15,500? What oil did you use? BIG savings vs the dealer
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
MarsMan is offline   Reply With Quote
Old 09-02-2015, 05:56 AM   #16
Mikegjax's Avatar
I have used the Youtube procedure more than once and it has worked each time. It takes several seconds for the peep to sound and it is not that loud.
I would review the procedure again then give it another try.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 09-02-2015, 07:44 AM   #17
If you just pulled into a valvoline quick oil change and they said they had your oil on hand that meets spec 229.52, you should ask them for the data sheet so you can "review" that claim.
And, if I were you, I would go back if you already had it done to ask for the spec sheet. The wrong oil WILL foul up your emmisions system, AND, heres the important part, if you can't prove you used the spec oil with "written" documentation (i.e. oil spec sheet) MB WILL void your warranty related to any failures associated there with. Just sayin'
You will be surprised what you can find out, just ask them.
Old 09-02-2015, 07:57 AM   #18
TARVIDSON
Thanks for replying, I will try it again, the valvoline oils that Mercedes has tested for 229.51 are Synpower MST 5W40 Full Synthetic and Synpower XTREME MST C3 5W40. Everything else on their 15,000 mile list was things like checking the belts for wear, windshield wipers etc., nothing that requires an ace mechanic. The 30,000 mile includes more. There was a maintenance record with my manual as well as on the internet.
Old 09-02-2015, 08:12 AM   #19
TARVIDSON
Thanks Still Kickin, the Valvoline Dealer I used was my usual mechanics shop. Most quick lube places would scare me with the Mercedes. I got the oil spec info right from Mercedes, a list of oils that they have tested. The only oil from the US that meets 229.52 that I saw on the list was Mobil 1 ESW 0-30.
bevo.mercedes-benz.com/bevolisten/229.51_en.html
Old 09-02-2015, 08:25 AM   #20
My point exactly. But anyway, your next big item will be your fuel filter change. Just helped a friend do his to learn the process. Very informative. I'll tackle that soon myself, as it's not that difficult, but I had the luxury of helping a friend, who did it before. Cost of filter from Freightliner about $70 bucks, MB I hear charges well over $375. Time wise took about 1 1/2 hrs. Part of the time is to swap out the WIF sensor from the spent to the new filter. That was, in my view the most difficult step. But, when, like I said, get to see it first, it all makes sense.
