Old 09-02-2015, 10:29 PM   #31
Looked at the Mobil 1 ESP on the NAPA site and it says for gasoline engines???
SSmbs is offline   Reply With Quote
Old 09-02-2015, 11:10 PM   #32
Iwannacamp's Avatar
mobil websiteClick image for larger version
Name:	ImageUploadedByForest River Forums1441253423.467953.jpg
ID:	87679Click image for larger version
Name:	ImageUploadedByForest River Forums1441253433.933011.jpg
ID:	87680Click image for larger version
Name:	ImageUploadedByForest River Forums1441253444.336122.jpg
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 09-03-2015, 08:20 AM   #33
Looks like the right stuff-ordering today.
Old 09-03-2015, 09:17 AM   #34
You are correct sir. What MB has done is in conjunction with Mobil is, agree to recommend that synthetic, since the previous one, 5w40 is no longer distributed in the US. Also, making the new one suitable for gasoline engines, which allows mobil to sell more of it. The previous oil had the moniker "formula M" meaning for Mercedes (diesel). You can just bet how much of that stuff got sold after spending oodles of formulation and testing with MB engineers. So, marketers step in and wella, the magic wand is waived, and we have a new recommended oil, broader use, different viscosity, etc. all is good, MAYBE. Just sayin'
Old 09-05-2015, 06:54 AM   #35
Mikegjax's Avatar
Originally Posted by CaptDan View Post
STILL KICKIN-Is this video close to changing the fuel filter below the intake?
FYI, there are 2 different fuel filters based on VIN and SA code. Parts catalog states "the correct filter must be verified at the vehicle". One filter sensor uses a 3 pin connector and the updated uses a 5 pin connector.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 09-05-2015, 08:11 AM   #36
CaptDan, I couldn't open the video, but it's my system. It did say it was for 2002-06 models on the title. The filter is located about center engine on top. When you partialy remove the air intake (Blk plastic) housing and swing it out of the way, you get a much better view. You will need one specialty tool called a; Collar Hose Clamp Pliers Clic and Clic-R Type. Got mine on ebay for around $13 bucks. There was a guy who posted pics in Sprinter Forum with his narative, showing the steps. Hope that helps.
Old 09-05-2015, 08:17 AM   #37
Heck, after you read that oil description, I'd vote for it if it was running for office even. I know we can't do anything about the viscosity change, so only time will tell. It's like a politician, promises, promises, then we get to see the performance.
Old 09-05-2015, 08:38 AM   #38
Found this; 2010 Fuel Filter Replacement - Sprinter-Forum
Old 09-05-2015, 08:56 AM   #39
Mikegjax's Avatar
Originally Posted by Still Kickin View Post
STILL KICKIN, those photos are close, but slightly different filter in my 2013. Procedure is close enough.
2014 Solera 24R
USN Retired
Old 09-05-2015, 10:02 AM   #40
Does any one have the Mann oil and fuel filter part numbers for a 2015 chassis? I am getting conflicting numbers with an online search.
