Old 11-01-2015, 11:15 AM   #1
Petersb's Avatar
Oil change
Looking for opinions I don't have that many miles 4666 is it better to change oil before winter. Or in the spring after the cold weather and snow. I've heard different thoughts as to which is the best way to go. Some say not good to let the old oil sit in pan all winter. But in the spring you can start off with new oil for the year. I run my mbs once a month and Gen to circulate oil. Appraite any feed back.
Petersb is offline   Reply With Quote
Old 11-01-2015, 11:21 AM   #2
I'm a fan of letting fresh oil sit in the engine through the winter. So, I would change it now.
bruceatlam is offline   Reply With Quote
Old 11-01-2015, 11:32 AM   #3
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
X 2 on fresh oil! Used oil may have some acids building up from use. Also, you are ready to go when you drag it out!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14
2001 Ford F-250 7.3
A Loving wife and Mason the always dirty dog!
Paulie1138 is offline   Reply With Quote
Old 11-01-2015, 01:51 PM   #4
I have always done in the spring but I believe it doesn't matter. If you have the 2015 chassis you have to change at 1 year or 20,000 miles so you have a lot of life left on that oil.
SSmbs is offline   Reply With Quote
Old 11-01-2015, 02:09 PM   #5
Crusadernoob's Avatar
Personally, I would wait, it's just a few months and you said you run it. You will not get it hot enough to evaporate the moisture you will have. The acids you will have in the oil are nothing to worry about in an engine with good oil and of sound mechanical condition, start fresh in the spring and not worry about it.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 11-01-2015, 05:11 PM   #6
Petersb's Avatar
Thanks for the thoughts greatly appreciated.
Old 11-01-2015, 05:46 PM   #7
Bluepill's Avatar
Also, having a full additive package with the new oil can't hurt during storage. Additives wear out with time and use.
2008 Itasca Meridian 37H
