Old 06-24-2014, 12:31 PM   #1
Oil change Frequency
OK I know the owners manual says to change the oil at every 10k and I recognize it is more costly to change more frequently but for some reason this just seems to go against my grain. The 2013 Solera replaces my 2004 Dodge Cummins Diesel which got a oil change every 3k but did not use synthetic oil. Do the majority of Mercedes Sprinter Diesel owners pretty much stick to 10k oil changes?
dkarius is offline   Reply With Quote
Old 06-24-2014, 12:50 PM   #2
At least I do. Coming up to the 30K mile service in the near term now. Maintenance "by the book" for all of my vehicles. None of them ever gave trouble (>250K miles on one of them without a hitch).
Engineers at MB spend lots of time figuring out the right balance on the maintenance pieces - why not trust them instead of somebody wanting to sell you spare parts and/or oil.
Reiner
2011 Solera
reinerka is offline   Reply With Quote
Old 06-24-2014, 12:59 PM   #3
2015 Solera 24R
DKarius, I'll be watching the reponse recieved on your question. I've had the same concern. Thanks. Longtimers to this forum will most likely tell us that there is an existing thread available with the information. I'll check on this, and will post a link if I find one.
Gary and Becky
Borrowing from Janis Joplin's "Me and Bobby McGee": Freedom is just another word for... RVing in a Solera.
RVing555 is offline   Reply With Quote
Old 06-24-2014, 01:14 PM   #4
2015 Solera 24R
dkarius, There is lots of information on oil changes on the Sprinter-Souce.com website. Membership is free. Owning a Sprinter, you may want to join that website as well. Lots of great info specific to Sprinters.
Gary and Becky
Old 06-24-2014, 05:27 PM   #5
papap's Avatar
Change mine every 10k. Change it myself. Have about 25k on it now. Plan to change fuel filter this time.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 06-24-2014, 08:30 PM   #6
2012 Solera
Papap - be careful changing the fuel filter. It is under a large air hose on our 2012 Solera. That air hose feeds the turbo. There is a "compensating ring" (part #A000 094 00 51) at the turbo inside that air hose. Mercedes says to replace that "compensating ring" whenever the hose is disturbed (which is necessary to replace the fuel filter). Mercedes has issued a Service Bulletin on this issue specifying how to replace the "Compensating Ring" and air hose - down to giving torque specs for the hose clamps! Service bulletin warns that failure to follow can result inn turbo failure or worse. My local Ford dealer - who claimed to be qualified to perform Sprinter maintenance - did not replace the "compensating ring". 8,000 miles later I had a turbo failure - sucked the compensating ring into the turbo - stranding me in Oklahoma City and costing over $3K not covered by warranty. Still battling Ford for reimbursement.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 06-24-2014, 08:38 PM   #7
papap's Avatar
Guess I'll let MB change fuel filter
Old 06-24-2014, 09:12 PM   #8
I agree, changing it every 10K is fine. Its important to replace the oil with the exact same amount you drain out. MB Sprinter can sense any overfill situation, give you a display in the instrument cluster, and then you would need to drain off the excess. Been there done that.
And your right, there are several threads, good ones I might add, that discuss changing the oil, along with code reset procedures.
Old 07-02-2014, 09:26 PM   #9
Our MB Sprinter manual (2015 Solera 24R) says to change the oil every 15K miles. My VW Jetta Sportwagen TDI is every 10K miles. I always changed the oil in my gas engines every 3K, but diesels are less frequent.
The Nutter Family
2015 Solera 24R
knutter is offline   Reply With Quote
Old 07-03-2014, 12:10 PM   #10
hkreck's Avatar
Change my at about 9000 and am now getting ready to change it again. I'm right at the 100 mile mark for the engine service light to come on. Like Papa I've been kick it around about doing the fuel filter change but something keeps telling me to take that part to Mercedes.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
