Old 11-30-2015, 12:31 AM   #1
on/off switch for holding tank heaters
Was under my 2015 24R installing Hellwig sway bar. Noticed heating pad on black and grey water tanks, Never mentioned on my walk thru last year when purchased. Is there a switch for these? Do they run on 12 volt or 120 v or both?
Will they drain batteries boondocking in cold weather?
Tommy G is offline   Reply With Quote
Old 11-30-2015, 04:27 AM   #2
Witch Doctor's Avatar
They should have switch to turn them on inside. They are on there own thermostat. Should come on at 40 degrees and off at 60 degrees. Most are 12v and will eat your battery up boondocking.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 11-30-2015, 06:28 AM   #3
Mikegjax's Avatar
The switch is located in the bank of switches with your water pump and others. Should be labeled Poler or Arctic. I do believe it is 12 volt. Not sure of the power draw.
Here is a thread with a little more info.
Tank heat pads for winterizing?
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-30-2015, 07:13 AM   #4
KenHwy61's Avatar
Tank heaters draw 6-7 amps. As mentioned, enough to drain a battery quickly if on for any length of time.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 11-30-2015, 11:29 AM   #5
Ready to Go
JeffLynn's Avatar
What if your on shore power?
The Lessmiller's
2001 F250 SD 7.3 Turbo
2013 Sanibel 39' 5th wheel.
JeffLynn is offline   Reply With Quote
Old 11-30-2015, 11:32 AM   #6
Mr. Dan's Avatar
My tank heater switch is the one in this pic with the red light in it (when ON). It is NOT labeled in my Wildcat.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 11-30-2015, 11:33 AM   #7
Left Coast
I've got a digital readout meter wired direct to battery....see no voltage drop on meter when turn'n on
Old 11-30-2015, 11:35 AM   #8
Mr. Dan's Avatar
Is the temp of the tanks below 40 or so degrees?
Sent (I think)
Old 11-30-2015, 11:36 AM   #9
Left Coast
19 here this morn
Old 11-30-2015, 11:37 AM   #10
Mr. Dan's Avatar
19 here this morn
Brrrrr.
I'm out!
heater, tank
