09-17-2014, 05:03 PM
Paint code
Anyone can tell me the color paint code for a Solera 2011, it is white but which one ?????
Envoyé de mon iPad à l'aide de Forest River Forums
Pierrôt and Sylvie D'Astous, Solera 2011
38 on 50 states, 9 on 10 provinces.
09-17-2014, 06:13 PM
The number on my 2013 is 9147, there's a vin # sticker on the driver seat base which has the number on it.
Henry & Tena
09-17-2014, 06:47 PM
Mine too is 9147 but this is the paint code for the cab.
The white gel coat on the coach is a different white.
09-17-2014, 07:12 PM
bclemens: Should be able to give us the codes direct from the Factory. I am interested in the codes for the full body for the 2013 Solera 24S please.
Capt Dan
Orlando, Florida
09-17-2014, 08:17 PM
Sorry about that Pierrot I thought they were the same, I checked a little more and found that there was suppose to be a tag on the coach with info on it but I can't find it. As CaptDan stated we need Brian to jump in on this.
Henry & Tena
09-18-2014, 03:09 PM
Commercial Member
Every coach ships out with a small bottle of touch up paint for each color. Typically in the glove box, dash area, etc.
If you take a picture of the unit, I can pull paint codes. But it may not be until next week. We just wrapped up our big dealer open house in Elkhart. I need to sleep for about 48 hours and then I can get some answers.
09-18-2014, 04:09 PM
Touch up paint included with MH? I had to go out and have my own mixed up to touch up stone chips there wasn't any in my 2014 3051s when I picked it up from the dealer new
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
09-18-2014, 05:38 PM
None in my '12 either. I sure would like to know what color mine is. It's the white one. Any chance you could do a year by year Brian. After you sleep of course.
09-18-2014, 06:46 PM
Oklahoma Proud
If you are looking to match the gelcoat, you will have to have a paint matched to it from swatches.
Gelcoat won't have a paint code. But your Gelcoat may be painted if you have full body paint.
Gelcoat is typically sold in three colors, black, white and neutral. You can tint the gelcoat to get different colors but there isn't a code typically associated with it.
Just go to an automotive paint store and have them mix some up for you or even some body shops may do it too.
Of course Mr Clemens may be able to get you something too.
Good luck!
09-19-2014, 10:23 AM
Commercial Member
Well, paint shop sent me this for the last 5 years, Again, I'm not in the office so you may need to pull each one up to verify which color is which. At some point I will have color schemes with the paint codes listed for each color when I get back in the office. This is not format on the site quite right...but it is the model...
color name/colorname (all bunched together)
colorcode/colorcode also bunched together
SUNSEEKER
LATTE PLATINUM
313a1 359a5 (Chrysler PAK)
315g1 356d1 (ford D4)
Black (gm WA984A) black (gm WA984A)
FORESTER
MAHOGANY TOREADOR RED
319d2 356b1
304g5 602g5 (Ford JL)
314e1 628a4 (vw Y)
310h1 black (Gm wa984A)
SOLERA
COPPER PLATINUM
318b1 GM 14U (303M)
604h2 FORD YZ
FORD PV GM (WA984A)
314f2 GM 16
SUNSEEKER
AUBURN LATTE
FORD PV GM 68U
FORD JL FORD PV
NISSAN C50 314F2
GM 68U (GM WA984A)
SUNSEEKER
CASHMERE GRAPHITE
318B1 319B1
604H2 618E1
314F2 356C2
FORESTER
OPAL WALNUT
430C1 319A1
314G2 604H2
308G1 314F2
316H2 311H2
09-19-2014, 06:57 PM
Thank you all, I just took the broken fiberglass and went to the auto paint shop. All I can say is White with Yellow !
Thanks Mr Clemens, I will keep the info somewhere.
