Old 02-18-2015, 11:32 AM   #1
Plumbing and check valves
To conserve water when showering on the MH I like to use the shower head on/off switch (I replaced the OEM with the Oxygenic). Unfortunately, this makes the water run cold.
I'm told I need to install check valves on the hot and cold water supply lines to the shower.
Has anyone done this?
Does anyone have a plumbing schematic for the 2015 24R?
Thanks, Jim
lacamastraveler is offline   Reply With Quote
Old 02-18-2015, 11:46 AM   #2
Dazed & Confused
M&K Hoffman's Avatar
I have put Oxygenic showers in two TT's w/o any other modification and not had that problem.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 02-18-2015, 07:44 PM   #3
You might want to check if your bypass valve is on. I read somewhere on this forum that the bypass valve on will cause a blending of both hot and cold.
Roger64 is offline   Reply With Quote
plumbing, valve
