Old 10-23-2015, 12:08 AM   #1
dukeboone's Avatar
Plumbing Question
I found some interesting plumbing underneath the bathroom sink. Can anyone tell me what's going on here? Looks like it could be a backflow valve or something? The upper black pipe going towards the wall has the word "flow" on it with an arrow towards the wall. Thanks!
Name:	2015-10-22 21.15.10.jpg
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 10-23-2015, 12:39 AM   #2
Fulltime family RVer
If you have a black tank flush, it's likely a black flow preventer.
Old 10-23-2015, 06:47 AM   #3
The same Pic. Has been Posted many times,mostly because it has Flooded the RV! Se:real Posts about replacing it! Youroo!!
Old 10-23-2015, 06:49 AM   #4
nomad297's Avatar
It is the check valve/vacuum breaker for your black tank flush.
Bruce
Old 10-23-2015, 11:08 AM   #5
dukeboone's Avatar
Super, thanks! Makes total sense, and I appreciate the help. Cheers
Old 10-23-2015, 11:14 AM   #6
Pod2Vibe's Avatar
Make sure the flow arrow is pointing towards the black tank and not the hose connection on the outside of your MBS.
On my Rpod it was reversed and the check valve would not allow water flow to the black tank flush sprayer.
It was correctly installed on my Vibe and Solera.
If you don't hear any spray activity when connected and pressurized, this is usually why.
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 10-23-2015, 12:34 PM   #7
dukeboone's Avatar
Thanks, the black tank flush was one of the first things I tested after reading some stories here about the check valve being installed wrong. The black tank flush seems to work fine and I can certainly hear the spray inside the tank. Happy to now know where the check valve is and can locate it if I ned to troubleshoot and/or monitor over time. Cheers!
plumbing
