Old 10-25-2015, 12:03 PM   #1
Possible Surburban Water Heater Problem
Good Afternoon,
Just replaced my Anode Rod on my Surburban water heater to find an unusual amount of Grout Grey/White residue. As I am cleaning out the tank more seems to come out. Is this normal? Has anyone else had this problem? Hope it does not leak! Thanks in advance-Just a little worried.
CaptDan
2013 Solera "S"
ID:	92799   Click image for larger version
CaptDan is offline   Reply With Quote
Old 10-25-2015, 12:05 PM   #2
TURBS's Avatar
It's normal.
Old 10-25-2015, 12:21 PM   #3
fonzie's Avatar
Originally Posted by TURBS View Post
It's normal.
X2, is this fist time you remove anode rod?
Fonzie
Old 10-25-2015, 12:33 PM   #4
The white stuff is calcium carbonate. Unless you have your own well, your municipal water supply is treated with calcium carbonate - it is called a "precipitate" because it attracts minute floating particles in the water, allowing them to sink to the bottom, leaving the water clear. In your water heater, small amounts remain and over months and years, the calcium settles at the bottom.
When you drain your water heater for winterizing, a small amount of water (maybe a quart) remains BELOW the level of the drain plug. If you use a turkey baster or siphon to drain water below the drain plug, you will extract a very milk like fluid; which is water mixed with calcium carbonate.
Now you know more than you wanted to know. Right?
MiataHoarder is offline   Reply With Quote
Old 10-25-2015, 12:42 PM   #5
Send a message via AIM to jk31668
after i drain the tank, i like to stick a nozze in the hole and flush it out a few times.
2010 sunseeker 3100ss
jk31668 is offline   Reply With Quote
Old 10-25-2015, 01:38 PM   #6
I bought a water tank cleaning nozzle which does just what jk31668 does. It's got a curved plastic nozzle that attaches to a garden hose, your are able to turn it around inside the tank to flush it out, similar to a black tank flush that you insert through the toilet. The first time you do it you are going to get a lot of calcium carbonate coming out.
tomrob1161 is offline   Reply With Quote
Old 10-25-2015, 01:43 PM   #7
Flybob's Avatar
Get a threaded /slip pvc connector and attach 4-5" of PVC pipe. Screw that into the anode rod connection then use the WH cleaning tool. The PVC will prevent the crud that comes out of the WH from running down the side of the RV.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-25-2015, 08:12 PM   #8
Thanks for all the replies. Now I can leave for Canyon Lake Texas from Orlando with "No Worries!" Happy Travels.
CaptDan
Old 10-26-2015, 07:32 AM   #9
MilCop4523's Avatar
Your tank is golden..
This one is not.
ID:	92875   Click image for larger version
ID:	92876   Click image for larger version
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 10-26-2015, 08:04 AM   #10
Dave Lyon's Avatar
X2 - the tank rinser works well.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
heater, water, water heater
