Power Steering leaks
Hello,
On a routine check, I witness suspicious amount of oil under my Solera (Sprinter 2010), just a few drops on the ground.
The color indicate it was power steering oil.
Found out the collar on the tube right next to the oil reservoir was completly lousse ! It took, 3 to 4 complete screwdriver turn to retight it good, that is were it was leaking.
While there, I also check the other collars, the two others were also a little bit slack but no leak.
Tought you would like to know and check your own.
Take care everybody.
Pierre
Pierrôt and Sylvie D'Astous, Solera 2011
38 on 50 states, 9 on 10 provinces.
