Old 06-11-2012, 01:43 PM   #1
Send a message via Skype™ to Pedrodasdas
Power step diagram needed
Hello,
I got a problem with my power step. It work perfectly with the switch (go in and out with the screen door) but does not retract automaticaly anymore when I put the ignition switch on.
I went through all my papers, got every documentation even for the propane regulator but impossible to find one on the power step.
If someone has an idea of what's wrong or, even better, a diagram of the electrical, I would greatly appreciate.
Pierrot
Pierrôt and Sylvie D'Astous, Solera 2011
Canada in summer, FL-TX-LO-NM-AZ in winter !
Nights camped in: 2014-96, 2015-139, 2016-89
Pedrodasdas is offline   Reply With Quote
Old 06-12-2012, 06:42 AM   #2
Coachmen Adrenaline
I am not certain as to the exact model of your step...but this should be close if not the exact one used at that time...the wire colors may vary, but the setup should be nearly identical.
http://www.strombergcarlson.com/pdf/...epElectric.pdf
The wire shown with a 6A fuse and "to fuse panel" is the yellow wire that should actually be tied to vehicle ignition signal, not fuse panel
jamiller45 is offline   Reply With Quote
Old 06-12-2012, 02:21 PM   #3
Thanks jamiller45,
It's axactly the one I have and exactly the documentation needed.
Now, just have to wait till that pouring rain stop !
My wife is taking the Solera out all alone to camp with our daughter and Grandson, I'll stay close to the phone
