Old 10-22-2015, 01:50 AM   #41
dukeboone's Avatar
I appreciate all the help. I looked again and didn't see any lights on the PD4000 series unit. I even removed the plastic cover and didn't see anything, aside from some information on these forums that FR may have installed something other than the PD4000 series all-in-one unit, I remain convinced at the moment there's no separate converter on mine. My only intention is to confirm what I have so I understand it and potentially help another user confirm as well since he bought the charge wizard remote for the PD9200. Anyway, I'll let you know if I discover otherwise. I figure this thread has gone down this rabbit hole long enough. Cheers!
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 10-22-2015, 06:24 AM   #42
TURBS's Avatar
When you took the cover off, if it had the all in one you should have seen the converter there. As well as a fan.
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-22-2015, 10:22 AM   #43
dukeboone's Avatar
Fan was certainly present as was some indications that I was looking at the converter module and not just a power distribution center. I suppose I could have mentioned that but I didn't know if the fan could also be a component of merely a power distribution center.
Old 10-22-2015, 10:30 AM   #44
TURBS's Avatar
Fan indicated that your converter was right behind it in the distribution panel.
The fan is attached to your drop in converter assembly.
Lower right.
TURBS
2008 duramax
2015 columbus 320RS
Old 10-22-2015, 10:34 AM   #45
dukeboone's Avatar
Super, thanks. I appreciate all your help!
Old 10-22-2015, 10:38 AM   #46
TURBS's Avatar
No problem.
Basically you have built in charge wizard technology!
Mine appears to be able to be adjusted as where your does not.
TURBS
2008 duramax
2015 columbus 320RS
converter, power
