07-17-2015, 09:41 AM
Progressive Dynamics 9200 Series INTELI-POWER converter Installation
I am planning on replacing my WFCO converter with a Progressive Dynamics 9200 Series INTELI-POWER converter next month along with coach battery replacement. I would appreciate any tips/info/problems (etc) that are Solera related on this installation-Thanks in advance.
CaptDan
2013 Solera "S"
07-17-2015, 12:17 PM
2012 Solera 24S
Dan,
I have a 2012 Solera "S" and I was able to get it to fit where the WFCO was previously located.
Tight fit, but it does.
I just set the pendant behind the door to the water filter (under the bed).
07-17-2015, 03:35 PM
There is that mod you can do by cutting an access door on the right side wall of the under bed outside cargo hold. That allows you better access to the wall where the wafco converter is anchored. Otherwise your working through the raised panel door at the base of the bed.
07-17-2015, 07:57 PM
2012 Solera 24S
I just removed the entire panel for the install.
Haven't had to access the converter since.
07-18-2015, 02:06 PM
And what does this do for you that the factory converter didn't?
07-18-2015, 02:13 PM
The PD 9200 series is what FR installs on the Solera now. It is a smarter, three stage converter.
The old WFCO is a battery killer from what I understand.
Pod2Vibe
Magnetic 2019 Isata 5 30FW 4X4 (arrived 2/15/19)
TOAD: 2014 Fiat 500 Abarth
2015 Solera MBS 24R - Hellwig/Sumo Equipped, Sold
(Sold the Vibe TT, as well)
07-18-2015, 07:19 PM
I cut a separate access panel in the plywood under the rear bed. Your model may be different.
2011 Solera 235S
Freightliner Badge
07-23-2015, 09:47 PM
What is the price difference, I just replaced the wfco with another ? Have a 2012 solera s
07-24-2015, 08:42 AM
The WFCO is also a three stage converter. How is it a battery killer Pod2vibe? Most all recent converters in the last several years are. I have read about unit failure issues higher than FR might expect. That might be the reason they switched. Mine has been operating fine for over three years.
Whats different with the PD 9200 over the old WFCO.
07-24-2015, 12:05 PM
I had a WFCO in my Rpod and it boiled the battery.
Multiple RV forums also mention this problem, especially when at one site/plugged into shore power for long periods.
The PD is a smarter converter and it also has the charge wizard dongle so you can monitor what it is doing at all times and change its mode at any time.
Pod2Vibe
09-15-2015, 12:33 PM
Anyone know when the PD converter started appearing in the Solera? We have a 2015 R mfg'd in 4/14. Where do you look for it?
2015 Solera 24R
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
09-15-2015, 01:33 PM
2015 Solera 24R
You should have the PD.
If you pull out the left drawer below the kitchen sink cupboard, you will see it on the 24R.
Pod2Vibe
09-15-2015, 07:18 PM
Thanks! Going to check it out tomorrow.
2015 Solera 24R
The Peterson Family
Southeast Louisiana
2015 Solera 24R
09-16-2015, 03:09 PM
Have the WFCO converter and except when it is being driven keep the RV connect to shore power 24/7. Have done this for the past two years, . Added water for the first time today. It did need some, but not dry by any means.
BTW, I do think the Progressive converter may be 4 stage.
2014 Solera 24R
USN Retired
09-16-2015, 04:42 PM
You are correct, Mike.
BOOST, NORMAL, STORAGE and DESULFATION
Pod2Vibe
09-16-2015, 04:48 PM
Mikegjax sorted me on this, the PD 9200 is a 4 stage since it has the desulfation mode.
Pod2Vibe
10-14-2015, 01:46 PM
Had to replace the WFCO with the Progressive Dynamic 9200. It fit int he same space as the WFCO Much better converter. We have 2012 Cedar Creek 29RE. New converter works great and ours came with the pendent when we ordered it from Amazon.
10-14-2015, 07:14 PM
Pod2Vibe, thanks for the tip on this pendant. Our 2016 MBS 2401R came with the PD9200 but not the pendant, so I ordered it. It's a great charger/maintainer. I like the fact that it will do AGM batteries as well.
jdyson
(former owner, went back to Class A)
(but enjoyed our brief 'experiment' in downsizing!)
'16 Forester MBS 2401R
Hellwig 7254, TireMinder A1A & Sumo Equipped
10-16-2015, 08:18 AM
Interesting on the fourth stage, desulferization. I'd be curious if that does in fact extend the battery life due to that occurrence (sulfur buildup) from multiple charge discharge cycles.
Also, for those who have switched the converter out, do you know if the output to the coach batteries is greater than the current supplied by the chassis alternator. Sprinters alternator, is very heavy duty in that it is rated at 14V/220 amp. That really kicks the coach batteries, if sensing a need for a charge when driving. I was wondering if the output on the gen set/transfer switch/converter path to the BM controller is similiar in charging current.
