Old 06-22-2015, 03:16 PM   #1
Propane regulator
Can anyone give me the model number or another brand number for the propane regulator immediately next to the propane tank. I have not been able to find one that matches on both ends or that vents down.
No Gen, no air, 110 in Arizona.
Dave & Pat
Solera 2014 24S
1992-2012 full timing
Part time
2012-present
groupleaderpj is offline   Reply With Quote
Old 06-23-2015, 09:50 PM   #2
OK. The regulator we had installed is an Olympian (Camco) #59323. It looks nothing like the one that went bad on our Solera 24S but the dealer said it would work. Our unit has 2 separate regulators on it, each one has a rubber hose running from the regulator to the far side of the coach. Tech had to climb under neath, disconnect the rubber hose at a union then disconnect the regulator. This is FYI only.
Dave & Pat
Solera 2014 24S
Part time
2012-present
Old 06-23-2015, 09:58 PM   #3
Ret E-9 Anchor-clanker
donanddona's Avatar
Got to agree on the replacement is not what was original. It works but not the same. Can you provide a picture of it? Mine is a auto change over.
donanddona is offline   Reply With Quote
Old 06-23-2015, 09:59 PM   #4
donanddona's Avatar
Sorry forgot to include the thumb nail.
http://www.amazon.com/Automatic-Chan...0R7Z3QSJX5SE51
Old 06-23-2015, 10:07 PM   #5
Ours is on a Solera body mounted tank, different but similar to the one you posted. Our regulator is back under cover and cannot get to it easy but there are pics if you just google it.
Dave & Pat
Solera 2014 24S
Part time
2012-present
Old 06-25-2015, 05:16 PM   #6
Maybe this one. http://www.amazon.com/Camco-59313-Ve...DateDescending
Old 06-29-2015, 01:43 PM   #7
regulator
I bought this at Amazon. Fits perfectly. Works great. Easy to install:
Camco 59323 Horizontal Two Stage Propane Regulator
dswiss is offline   Reply With Quote
Old 06-29-2015, 05:04 PM   #8
Couple questions to clean up this thread; 1. the OP has a 24s and wanted to know the exact replacement. 2. what model Solera do you have, and was the camco 59323 a direct match to yours.
Old 06-30-2015, 05:20 AM   #9
I have a 2013 24R.
I would say it is a direct replacement. Slightly bigger, but identical layout, fittings, threads, etc.
propane
