I have use one on a boat, the Solenoid is normal located at the propane tanks on a boat, there is a light on the panel that let you know when the Solenoid is on and gas to the system. Most cruising boat use them as the hull is big hole in the water that would trap propane as it would settle in as it is heavier then air. Never had a problem.
