Old 08-13-2015, 09:16 AM   #1
CharSolera's Avatar
Propane Tank Filling - Newbie Question
I have a 2014 24S Solera. I need to have the propane filled. The tank is built into the RV. The local U-Haul says they have propane and you do the refill yourself (they charge by the gallon). Is it OK to fill the Solera tank where you pump yourself? I've read about places where trained people do the filling - but if it's something I can do myself, I can use this place.
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
CharSolera is offline   Reply With Quote
Old 08-13-2015, 09:20 AM   #2
Old Enough to Know Better
gasman6674's Avatar
Unless you have been properly trained I would not recommend you fill your own. You could get burned (freeze burn) or vent to much product. I cant believe do to liability they would let you do that. I would find someone else.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 08-13-2015, 09:23 AM   #3
Phat Phrog Stunt Crew
elind's Avatar
I am not sure if self serve LP filling exists. It's a little more involved than filling up you gasoline tank.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 08-13-2015, 09:43 AM   #4
iceblaze580's Avatar
Yeah I would go some where else
iceblaze580 is offline   Reply With Quote
Old 08-13-2015, 10:03 AM   #5
PolarisGuy's Avatar
I worked for a large RV dealership for a few years when I was younger. On a freezing cold morning a customer came in to get propane. I had been trained, done it a hundred times, and yet still made a crucial mistake and didn't have the threads on straight due to my hands being so cold. I flipped the on switch and propane covered my entire manhood area hence sending me to the hospital. Needless to say, I was called 'Frosty" by all my other techs after that. Lesson learned.
RV: 2016 Stealth WA2916 Toy Hauler
TV: 2005 F250 PSD
2012 Polaris Sportsman 850XP
2014 Brute Force 300 (daughters)
2016 Days Camped: 22
Check Us Out On YOUTUBE!!
PolarisGuy is offline   Reply With Quote
Old 08-13-2015, 11:22 AM   #6
Pod2Vibe's Avatar
Frosty is right, be careful! =)
Btw, my local Uhaul fills my tank all the time.
They ask that no one is in the rig, all appliances are off and that I turn off the valve.
Have never seen a self serve LP station. You have to be trained on the equip.
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 08-13-2015, 11:32 AM   #7
CharSolera's Avatar
Thank you all for your quick replies! It sounds like I'll go someplace else and have them do the filling.
Charlene
2014 Solera 24S
Old 08-13-2015, 11:49 AM   #8
vinmaker's Avatar
Self serve LP? Never heard of that either. I would not feel comfortable doing that. I think your best bet is to go to a professional and have it done.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-13-2015, 12:02 PM   #9
I thought it was state law you had to be certified to fill propane. Make sure that the bleeder valve is open some kid at Camping World didn't open it and blew the seals out of the regulator. Then he tried to deny it luckily I was standing there when it happened.
Myrle is offline   Reply With Quote
Old 08-13-2015, 12:06 PM   #10
Hicks43's Avatar
Amerigas supply's all the u hauls with propane. They are trained to fill it for you. If you don't mind where is this uhaul located at. I'm a service tech for amerigas. This needs to be addressed swiftly. Thank you jim
Sent from my iPhone using Forest River Forums 2015 21ss havein fun
Hicks43 is offline   Reply With Quote
newbie, propane, tank
