Old 08-11-2013, 02:20 PM   #1
Propane tank size how many gallons
Anyone the capacity of the propane tank, Thanks
13larry is offline   Reply With Quote
Old 08-11-2013, 02:44 PM   #2
Oakman's Avatar
It depends on which brand and type of RV you have. Give us a clue. Most are usually 20 or 30 pound tanks.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 08-11-2013, 03:48 PM   #3
Propane tanks are usually sized by pounds not gallons.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 08-11-2013, 03:58 PM   #4
TomStacey616's Avatar
Isn't it 4.7 gallons for a "20#" tank?
2010 Tundra DC SR5 TRD 5.7L towpkg (gone)
2008 F350 Lariat CC DRW 6.4PSD
2013 PT Tracer 3200BHT
BlueOX SwayPro (used when hauling cart too)
TomStacey616 is offline   Reply With Quote
Old 08-11-2013, 03:59 PM   #5
Sorry this was so confusing. I have a 2013 Solera, and posted this on the Solera forum. It has a fixed tank, It is not in pounds since you get it refilled at a gallon dispensing pump.
Old 08-11-2013, 04:34 PM   #6
it is a 12.2 gallon tank that at 80 percent filled is 9.8 gallons net. Brian Clemens has a post on this either in the sunseeker or this forum
gerrym51 is offline   Reply With Quote
Old 08-11-2013, 04:37 PM   #7
2012 Solera
My 2012 Solera "S" tank holds 9.8 gallons (actual propane capacity). Tank actual size is somewhat larger.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-11-2013, 05:39 PM   #8
redneck 92's Avatar
Propane tank size
My fixed propane tank is 20 gallons. Not sure of how many pounds that is.
redneck 92 is offline   Reply With Quote
Old 08-12-2013, 02:32 AM   #9
GM
bclemens's Avatar
Yes, be careful because some MFG's list WC (water weight). Why? I have no idea, since you're never carrying water in that tank. The only number that matters is 80% of water weight capacity. Which on the Solera, as stated is 9.8 gallons. (or multiply that by 4.2 to get lbs).
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
propane, tank
