Old 01-21-2015, 03:46 PM   #1
pros and cons of full body paint
We are in the process of purchasing a new 2400S Sunseeker and would like to know if the full body paint is worth the additional cost. Thanks!
Rick and Cara is offline   Reply With Quote
Old 01-21-2015, 03:54 PM   #2
VinceU's Avatar
On my 2nd full paint scheme and frankly it makes the coach appear enormously better, richer and most important finished. Forget the cost, it's only a profit center for them anyway. Negotiate total cost to you- otherwise they'll fragment your arguments.
VinceU is online now   Reply With Quote
Old 01-21-2015, 04:12 PM   #3
Sandiegodoug's Avatar
Ours is almost 3 and it still looks brand new
Sandiegodoug is offline   Reply With Quote
Old 01-21-2015, 04:14 PM   #4
Fulltime family RVer
I would guess a possible con is that colors soak in heat more than plain white. But, I'm not sure I'd let that be enough to dissuade me from it- they just look sharp.
Old 01-21-2015, 04:17 PM   #5
Jestercyco's Avatar
I really looked at the full body paint, but the DW and I could not get the look that we wanted to go with the tuxedo black Ford. The money was not a determent. They sure look good!
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 01-21-2015, 04:18 PM   #6
I would say the bottom line is -THERE ARE NO PROS OR CONS, IF YOU LIKE IT, BUY IT
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 01-21-2015, 06:01 PM   #7
'79 Bonneville
we just traded in a full body and ordered white - main reason is touch-up is a lot easier with white. The colors change a little with age and white does not. Also, I think the full body reminds me of Nike and is a bit overdone - too "swoopy". I'm an engineer and my tastes lean toward simplicity.
But if you like full body enough to justify the cost, just do it. Consider the value of every time you feel good about the look of it worth an estimated amount of money an multiply that by the estimated number of times you will appreciate it - then just do the math. If the total is worth more than the cost, it's a good investment.
bcunning is offline   Reply With Quote
Old 01-22-2015, 12:05 PM   #8
Boso's Avatar
Paint
no cons except cost if that's not a problem but full body paint I didn't on my last on and regret it every time I see a pretty one with the f b p
Boso is offline   Reply With Quote
Old 01-22-2015, 01:06 PM   #9
Not sure if the white has decals or paint but, if decals, for sure they will peel and fade eventually. If the full paint is maintained, it'll last a long, long, time.
SkipnTerri is offline   Reply With Quote
Old 01-22-2015, 01:43 PM   #10
We were afraid the decals would pull off. That is our main concern.
